Boost Gauge Install
Jact
  • New Member
  • Member For: 16y 7m 27d
Hi guys,
I've done some searching but surprisingly little comes up about the specifics of this.
Where exactly have people connected their T-Piece for a mechanical boost gauge on a XR6T?
I fitted mine to the manifold end of the blow-off-valve but it doesn't seem to give any pressure.
https://itbtra.bay.livefilestore.com/y1p_V33iy1GPjfvfuRelTo9wEx8T0aWr89NhTG92tgdd8o_eBDckqvBP2V4K8Y2bcZjpMCmXn2Rw-Y/DSC_0710.jpg
  • Member For: 14y 5m 18d
Pic doesn't work.
Not sure if mechanical is the same as electric but on my electric I T'd into the vacuum line coming off the BOV and it worked fine.
Are you getting any readings at all or is the gauge stuck on zero the whole time, could be that the wiring isn't right too?
  • Member For: 16y 4m 16d
  • New Member
  On 12/02/2013 at 10:20 PM, Bellato said:
Pic doesn't work.
DSC_0710.jpg?psid=1
Ok hopefully you can see the pic now?
That does sound like the same place I have my T piece, but the gauge just sites on 0 psi, it doesn't move at all when I turn on the car or rev it.
  On 12/02/2013 at 10:26 PM, Paulie2256 said:
Thanks for the links Paulie, it sound like others have put the T-piece coming off the BOV to.
Hmmm maybe my new gauge is dead...
Edited by Jact
  • New Member
Ok so the install pic above is correct guys it was the boost gauge causing the problem. The needle was stuck against the glass and not moving.
Now when I turn the car on the gauge instantly jumps down to about negative 40~50 psi and driving around I can get it up to about positive 10~12 psi.
Surprisingly to me the boost doesn't begin to come on until about 60% throttle, no matter what RPM its doing!
Maybe this is a dumb question but isn't the boost from the turbo proportional to the engine RPM not the throttle position?
  • Member For: 18y 10m 18d
Has the car been tuned? Those areas can be altered to bring boost on at earlier tps, that's a nice thing to do a conservative low boost tune, itll make it feel pretty quick ;)
  • 2 weeks later...
  • New Member
  On 13/02/2013 at 11:09 AM, stroller said:
yes it is, should come on around 2000
Driving around I've noticed the boost doesn't fully come on until about 3500 RPM
Yeah it's been tuned (so Ford tell me) and the boost gauge is hitting about 12psi. It really doesn't feel that quick but I think that's for another topic...
