Injectors And Fuel Pump
  • Here since the start...
  • Member For: 21y 9m 26d
...while trying to keep the manual box alive until the series 2's get here.
Then what? Take it all out and put it in the series 2 or leave it for the new owner and start all over again with the series 2?
  • Replies 68
  • Created
  • Last Reply
Top Posters In This Topic
  • Formerly Turbo6
  • Member For: 22y 1m 13d
Well, if they give me the right money, I will sell it as is and start over and do the same thing again or the plan was to pull it all out and put it in the series 2. Hopefully, the rumours are all true about the stronger transmissions ............
The price I was quoted for the injectors was $145 (or $147 I can't recall) each and the fuel pump (which flows 600HP) was $340 from memory. The injectors are multi orifice and 440cc which sounds very similar to APS. Throw in $875 for the intercooler and it works out pretty cheap really.
Can't wait! :hrmm:
Edited by Turbo6
  • Member For: 21y 11m 15d
Are these the same injectors that APS is using?  How much are the injectors and are they anything special?
Thanks,
Kris.
Hi Chris, They are not the injectors we use, and they are pintle type (not multi orifige type) and not a very nice injector, I know as we have tested two sets, they are going into the rubbish bin. The injectors we utilise are genuine bosch, not cheap and horrible, poor copies of the real deal .
Peter
APS
  • Formerly Turbo6
Peter
APS
Peter, just to clarify again, I asked these specific questions and was told that they are in fact the multi orifice type and are Bosch. Am I being told fibblies?? :(
Ww tested a number of sets prior to xmas, from the people you mentioned ealier, they were pintle type(not multi orifice type) they did not flow what we were told (we checked each for flow no two injectors were the same) and in short (I'd better be careful what I say in a public domain) they were very poor injectors, the worst that I have ever seen and I have seen some horribler injectors over the last 18 years. Of course they may have imported some genuine Bosch injectors, if so and there multi orifice type and the correct size then go for it. I suspect the injectors will end up being cheap nasty copies if they are the same as I have tested. Be very careful, I know more about this issue, though I am thin ice now.
Peter
APS
From what I understand APS (possibly others aswell) conducted tests that have shown the performance of the ford fuel pump when new can provide the pressure but over time the performance of the pump dramatically decreases to the point where it's incapable of providing enough pressure, to an engine with phase 2 or higher modifications.
This is spot on. Factory fuel pumps can and do quite often drop fuel pressure over a short period of time, and when asked to work overtime by a rising rate pressure reg, its an accident looking for somewhere to happen. You only need a short period of time with the engine running lean (caused by low fuel pressure) and you can end up with a massive engine damage caused through detonation. Why take the risk, its just not worth it.
Peter
APS
  • It's All In Your Mind
  • Member For: 21y 3m 23d
Good luck Doc,
If you can, please let us know what the dealer finds (what code numbers or descriptions exactly). We might be able to offer some (Eastern State ;) ) help to your dealer if he is stuck.
Lachlan
:smilielol:
Hi Lachlan, it was the manifold pressure switch, apparently faulty.
  • Moderating Team
  • Member For: 22y 21d
Doc, how much did you end up paying for the PWR 'cooler??
:unsure:
$875 delivered. Nice piece of gear bolts straight in, inlet and outlet are both on R.h side so you also lose about 80cm of hose.
I got a photo of this bit of sexual gear at Summernats, will post up later tonight! Looks very nice and well built. Definately worth the 875 clams.
Hypnodoc, have you installed the cooler yet?
