sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 5m 21d Gender: Male Location: Far north queensland Posted 08/02/13 10:51 AM Share Posted 08/02/13 10:51 AM Get Kosij to give you a hand, he's the man at this 1 Link to comment https://www.fordxr6turbo.com/forum/topic/83916-helpppppppp-zf-6-speed/page/2/#findComment-1360547 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 10m 16d Gender: Male Location: Adelaide Posted 08/02/13 10:57 AM Share Posted 08/02/13 10:57 AM Oh dear ..... Link to comment https://www.fordxr6turbo.com/forum/topic/83916-helpppppppp-zf-6-speed/page/2/#findComment-1360549 Share on other sites More sharing options...
Danxr Member 67 Member For: 16y 5m 7d Gender: Male Location: Perth WA Duncraig / Wanneroo Posted 08/02/13 11:20 AM Author Share Posted 08/02/13 11:20 AM whose Kosij google won't answer my question Link to comment https://www.fordxr6turbo.com/forum/topic/83916-helpppppppp-zf-6-speed/page/2/#findComment-1360552 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 4m 23d Gender: Male Location: Probably above atmospheric pressure Posted 08/02/13 11:40 AM Share Posted 08/02/13 11:40 AM Ignore them, they are taking the piss The joke is Kosij has loads of car trouble.If you having tranny troubles I feel bad for you son, I got 99 problems but a shake aint one!Looks like you're in for a wallet raping :(I hope I never have this happen. Link to comment https://www.fordxr6turbo.com/forum/topic/83916-helpppppppp-zf-6-speed/page/2/#findComment-1360562 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 10m 16d Gender: Male Location: Adelaide Posted 08/02/13 11:41 AM Share Posted 08/02/13 11:41 AM Dan what have u got to loose rip it your old valve body and wack it in Link to comment https://www.fordxr6turbo.com/forum/topic/83916-helpppppppp-zf-6-speed/page/2/#findComment-1360565 Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 4m 25d Gender: Male Location: SE Melbourne Posted 08/02/13 12:39 PM Share Posted 08/02/13 12:39 PM Donor PCM won't work in this case cause you can't use fg PCM with bf. You are up a creek. Manual FTW Link to comment https://www.fordxr6turbo.com/forum/topic/83916-helpppppppp-zf-6-speed/page/2/#findComment-1360575 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 6m 24d Gender: Male Location: Perth Posted 08/02/13 01:02 PM Share Posted 08/02/13 01:02 PM On 08/02/2013 at 10:47 AM, J@SNOT said: Look this is what ive found out from a bit of reaserch over the years1- swop valve body to old one 2- get the ecu/tcm from donor car and a " mate" that works at ford and go for gold in changing it all over ( ecu/tcm ) and reprogram everything 3- buy new mechatronics/valve body ( yes $3000 rrp ) Look its a bitch either way but this is the crap that has to happen I dont know anyone that can hack the tcm to accept a new mechatronic unit yet Oh and 4- diff bush replacement CheersIs "look" the new cheers? Look, I'm not saying it is but it's up there. Link to comment https://www.fordxr6turbo.com/forum/topic/83916-helpppppppp-zf-6-speed/page/2/#findComment-1360581 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 10m 16d Gender: Male Location: Adelaide Posted 08/02/13 08:49 PM Share Posted 08/02/13 08:49 PM Look ralphy look Srs look cheers 2256 is right forgot u have b series and donor is fg Is donor was b series ud have a chance at exu/tcm swop Look Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/83916-helpppppppp-zf-6-speed/page/2/#findComment-1360639 Share on other sites More sharing options...
Jmr84 Member 31 Member For: 12y 5m 15d Gender: Male Location: Ipswich, queensland Posted 08/02/13 09:46 PM Share Posted 08/02/13 09:46 PM Hey guys, bit of a xr6 noob here. What happened for the trans cooler to fail? I have a bf xr6t ute with a 6 Spd and going to put a cooler on it, so just concerned if this should still go ahead. Tips? Cheers. Link to comment https://www.fordxr6turbo.com/forum/topic/83916-helpppppppp-zf-6-speed/page/2/#findComment-1360653 Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 21y 11m 21d Gender: Male Location: Victoria Posted 08/02/13 09:57 PM Share Posted 08/02/13 09:57 PM It already has a cooler in it. The stock cooler uses the coolant to draw the heat out of the trans fluid. The issue that happens with some of these coolers is that they can split and leak coolant into the trans which if not detected very quickly will spell the end for the trans. Link to comment https://www.fordxr6turbo.com/forum/topic/83916-helpppppppp-zf-6-speed/page/2/#findComment-1360656 Share on other sites More sharing options...
