  • Member For: 16y 5m 13d
After Tranny cooler failed I've got my replacement gearbox
car: Falcon BF series 2 xr6 turbo with the 6 speed
car worked like a treat before facing the death sentence from the tranny cooler
ofcourse the tranny cooler failed instantly killing the gearbox ect ect
well got a new/2nd hand gearbox chose the lowest km one was removed from a 2010 fg xr6turbo with 17,000kms paid $1500
installed it this morning got it up and running no worries but now the bloody thing is stuck in 1st gear will not change
the p-symbol keeps flashing and doesn't even goto manual mode but when you select all the gear selections they all flash
https://www.fordxr6turbo.com/forum/topic/83916-helpppppppp-zf-6-speed/
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 10m 22d
Lol did u change the mechtronics unit attached to the valve body from your old zf ?
There paired with the tcm
your new zf is looking for its old tcm
Oh sh*t damn no one told me that well that just sucks I guess now that its in the car I don't think there will be away of changing it
  On 08/02/2013 at 10:05 AM, bionicxr6t05 said:
Not by ford unsure about the aftermarket...
aftermarket???
because my old gearbox did 300,000 kms and I dont want to use any parts from my old one
so I assume its all the same with all the 6 speed boxes I.e if you swap a bf 6 speed with a bf 6 speed will the valve body need to be changed aswell
haha just took the plastic sump off my old one and few springs and ball bearing fell out in the white milky oil
Look this is what ive found out from a bit of reaserch over the years
1- swop valve body to old one
2- get the ecu/tcm from donor car and a " mate" that works at ford and go for gold in changing it all over ( ecu/tcm ) and reprogram everything
3- buy new mechatronics/valve body ( yes $3000 rrp )
Look its a bitch either way but this is the crap that has to happen
I dont know anyone that can hack the tcm to accept a new mechatronic unit yet
Oh and
4- diff bush replacement
Cheers
