heathb New Member 19 Member For: 12y 3m 8d Gender: Male Posted 07/02/13 10:18 AM Author Share Posted 07/02/13 10:18 AM cheers for all the feed back, will check these things tomorrow.@Bonjaz, no after market fuel pump Link to comment https://www.fordxr6turbo.com/forum/topic/83909-wont-boost-past-4000-rpm/page/2/#findComment-1360091 Share on other sites More sharing options...
NickBA-XR6T Bronze Donating Members 386 Member For: 13y 1m 5d Posted 08/02/13 12:55 AM Share Posted 08/02/13 12:55 AM My money is on the cat being blocked. Fuel system issues tend to creep up slowly and degrade over time, such as dirty filters and injectors etc. Performance would have eroded gradually not just BAM! Link to comment https://www.fordxr6turbo.com/forum/topic/83909-wont-boost-past-4000-rpm/page/2/#findComment-1360338 Share on other sites More sharing options...
Bonjaz Donating Members 1,841 Member For: 16y 4m 9d Gender: Male Location: CQ Posted 08/02/13 03:10 AM Share Posted 08/02/13 03:10 AM If a hose popped off intank pump or it finally corroded away due to aftermarket pump and not proper hose used...I leant the hard way after about 4k rpm nothing Link to comment https://www.fordxr6turbo.com/forum/topic/83909-wont-boost-past-4000-rpm/page/2/#findComment-1360373 Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 21y 11m 22d Gender: Male Location: Victoria Posted 08/02/13 03:11 AM Share Posted 08/02/13 03:11 AM This car has a stock fuel setup. Link to comment https://www.fordxr6turbo.com/forum/topic/83909-wont-boost-past-4000-rpm/page/2/#findComment-1360374 Share on other sites More sharing options...
heathb New Member 19 Member For: 12y 3m 8d Gender: Male Posted 08/02/13 05:45 AM Author Share Posted 08/02/13 05:45 AM Just to clarify the car will go past 4000 rpm while easing it there but not while under full load. Link to comment https://www.fordxr6turbo.com/forum/topic/83909-wont-boost-past-4000-rpm/page/2/#findComment-1360425 Share on other sites More sharing options...
xr6thsveta Donating Members 100 Member For: 12y 11m 12d Gender: Male Location: Palmerston North. New Zealand Posted 08/02/13 07:00 AM Share Posted 08/02/13 07:00 AM Did you change the air filter ? Link to comment https://www.fordxr6turbo.com/forum/topic/83909-wont-boost-past-4000-rpm/page/2/#findComment-1360471 Share on other sites More sharing options...
Bonjaz Donating Members 1,841 Member For: 16y 4m 9d Gender: Male Location: CQ Posted 08/02/13 07:10 AM Share Posted 08/02/13 07:10 AM This car has a stock fuel setup.I know I was just saying that a fuel problem can cause it to just cut at a certain point but it is unlikely it's this guys problem, your probably on the money with the cat... Link to comment https://www.fordxr6turbo.com/forum/topic/83909-wont-boost-past-4000-rpm/page/2/#findComment-1360476 Share on other sites More sharing options...
heathb New Member 19 Member For: 12y 3m 8d Gender: Male Posted 08/02/13 08:22 AM Author Share Posted 08/02/13 08:22 AM air filter is stock Link to comment https://www.fordxr6turbo.com/forum/topic/83909-wont-boost-past-4000-rpm/page/2/#findComment-1360503 Share on other sites More sharing options...
P_BA_XR6 Member 271 Member For: 16y 10m 15d Gender: Male Location: Castle Hill Posted 08/02/13 09:53 AM Share Posted 08/02/13 09:53 AM I would say cat, if makes a rattle or funny exhaust noise near the front def the cat, if its like a pulsing feeling under acceleration either fuel or spark. Spark tends to be issue ford have crap coil packs and don't buy vdo replacements learnt the hard way,Just for general maintance when the engines cold, tighten all exhaust manifold bolts every 15 to 20000kms if you drive it hard, 20 to 40 k if you drive it like a granny! Check the 4 turbo bolts and also dump pipe bolts. If you wanna check for spark issues or to help find out if there something wrong I believe looking at the spark plugs it tells you if you rich, lean, or have a dead coil if its none of the above something stupied like a cat. Or freak issue which is rare as f...k! Wrong size fuse which holds just enough to make fuel to start the car and cruise but then give out on you when you gun it. Happened once and I was pulling my hair out because I was looking at all major issue not thinking about simple, but that was a surge tank fuse. 15 amp on Bosch 044 melted it but was in a bad spot inside battery box under a ute tray near exhaust. Done by a previous tunner not the greatest idea Link to comment https://www.fordxr6turbo.com/forum/topic/83909-wont-boost-past-4000-rpm/page/2/#findComment-1360528 Share on other sites More sharing options...
NickBA-XR6T Bronze Donating Members 386 Member For: 13y 1m 5d Posted 09/02/13 02:48 AM Share Posted 09/02/13 02:48 AM Check some of the simple things above and if you have no luck take it to a good mechanic. Link to comment https://www.fordxr6turbo.com/forum/topic/83909-wont-boost-past-4000-rpm/page/2/#findComment-1360754 Share on other sites More sharing options...
