  • Member For: 16y 4m 24d
Hey guys,
My car developed a front end noise last night as I drove home and was doing it again this morning.
Its a metal sound, kinda sounds trailer moving around on a tow ball. From driving it this morning it only happens at lower speeds, when under braking and predominately when turning left. Its creeks sightly when turning right.
There is no noise when on rough or uneven surfaces and otherwise the car drives fine, it doesnt pull to one side and brakes as per normal.
Its due for a service but any ideas of what it could be before I take it in?
Cheers
https://www.fordxr6turbo.com/forum/topic/83887-front-end-noise/
  • Member For: 13y 8m 8d
Probably best to lift it up and pull the wheels off so you can check the top of the sway bar link is tight. Mine was tight at the bottom but slightly loose up top and mainly made noise on bumpy road and during hard/fast weight transfer from side to side.
Hope you find the cause of your clunk, I know first hand how annoying they can be :shakefist:
