STIFLR Donating Members 572 Member For: 16y 4m 21d Gender: Male Location: Victoria Posted 05/02/13 09:44 PM Share Posted 05/02/13 09:44 PM Hey guys, My car developed a front end noise last night as I drove home and was doing it again this morning.Its a metal sound, kinda sounds trailer moving around on a tow ball. From driving it this morning it only happens at lower speeds, when under braking and predominately when turning left. Its creeks sightly when turning right.There is no noise when on rough or uneven surfaces and otherwise the car drives fine, it doesnt pull to one side and brakes as per normal.Its due for a service but any ideas of what it could be before I take it in?Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/83887-front-end-noise/ Share on other sites More sharing options...
BRK Member 361 Member For: 13y 4m 17d Gender: Male Location: Perth Posted 06/02/13 02:58 AM Share Posted 06/02/13 02:58 AM Checked the brakes - ?? Link to comment https://www.fordxr6turbo.com/forum/topic/83887-front-end-noise/#findComment-1359284 Share on other sites More sharing options...
tdt84 New Member 18 Member For: 13y 8m 5d Gender: Male Location: Cairns Posted 13/02/13 12:02 AM Share Posted 13/02/13 12:02 AM Sway bar links need tightening Link to comment https://www.fordxr6turbo.com/forum/topic/83887-front-end-noise/#findComment-1362208 Share on other sites More sharing options...
STIFLR Donating Members 572 Member For: 16y 4m 21d Gender: Male Location: Victoria Posted 13/02/13 01:25 AM Author Share Posted 13/02/13 01:25 AM Brakes all good. Cheers tdt I'll check but the noise has gone, only lasted a day Link to comment https://www.fordxr6turbo.com/forum/topic/83887-front-end-noise/#findComment-1362241 Share on other sites More sharing options...
Bulletime Donating Members 937 Member For: 14y 3m 21d Gender: Male Posted 13/02/13 08:35 AM Share Posted 13/02/13 08:35 AM I've for bit of a rattling too that is well described the way u did, except more noticeable over bumps and bumpy roads. Let us know if the away bar links was it Link to comment https://www.fordxr6turbo.com/forum/topic/83887-front-end-noise/#findComment-1362412 Share on other sites More sharing options...
STIFLR Donating Members 572 Member For: 16y 4m 21d Gender: Male Location: Victoria Posted 13/02/13 09:13 AM Author Share Posted 13/02/13 09:13 AM Will do mate. I'll get under and have a look on the weekend Link to comment https://www.fordxr6turbo.com/forum/topic/83887-front-end-noise/#findComment-1362451 Share on other sites More sharing options...
tdt84 New Member 18 Member For: 13y 8m 5d Gender: Male Location: Cairns Posted 14/02/13 12:34 AM Share Posted 14/02/13 12:34 AM Probably best to lift it up and pull the wheels off so you can check the top of the sway bar link is tight. Mine was tight at the bottom but slightly loose up top and mainly made noise on bumpy road and during hard/fast weight transfer from side to side.Hope you find the cause of your clunk, I know first hand how annoying they can be Link to comment https://www.fordxr6turbo.com/forum/topic/83887-front-end-noise/#findComment-1362698 Share on other sites More sharing options...
