Apple Ipod Thread (Merged Topic)
Velvet Glove
  • Bored Member
  • Administrator
  • Member For: 22y 3m 6d
Your never going to get CD quality through a 3mm jack.....
You just arnt pushing hard enough then!
Burn the same tracks to a disc and play them against the sound coming from the MP3 player and you'll notice the difference straight away.
....oh hang on the Fords dont play MP3 discs do they.... :gunsfiring:
In any case......Your never going to get CD quality through a 3mm jack.....
  • Member For: 17y 1m 10d
A friend proved to me that using an iPod as a source is not a handicap - they sound extremely good, even in a pretty good sounding $20K home system. He loaded the iPod with uncompressed tracks (not MP3s) and plugged it into his HT system via 3mm jack.
It sounded fantastic - the same or better than playing the original CD on his CD player.
The quality of the MP3s is the biggest issue. I rip mine at the highest res available in the iTunes settings. Most that are done by others and "shared" are not. I think that is the source of the perception that iPods sound like rubbish.
  • Member For: 17y 8m 25d
I'm going to do this as I'm sick of my POS ford 6 stacker not playing burnt cd's
  • RUS531
  • Member For: 18y 6m
as stated in other posts. I made a "un-amplified" input for my I pod for about 5 bucks useing stuff from dicksmith...and I get no humming noise at any volume, with or without a charger plugged in.
My secret... shielded four core cable.
I'm very picking on sound quality and I agree with dags, its not as good as a CD can be but its dam close.
also volume is great, quite loud. I use a 6oGb ipod video
Edited by RUS531
  • Member For: 17y 8m 15d
Complete rubbish. A 3.5mm plug will easily carry CD quailty sound. The IPOD on the other hand will almost never send CD quality. Noticing the difference comes down to the quality level of compression, the type of music, speakers and most of all, your ears.
  • Member For: 18y 5m 11d
Your ipod should be at full volume.
If the Aux is then noticably louder than factory CD (with the ipod at full volume) then there are some variable resistors (or gain controls) inside the Ford Aux input box. If these are turned up to high it make the ipod louder than the CD. PLUS these gains st to high are the main contributer to the whine some people get.
  • 1 month later...
  • Member For: 16y 8m 16d
I set up my own aux input for no cost and there is no whine. (volume is about 1 or 2 less than CD)
All you need:
3mm plug to rca cable (I had 1 spare at home)
5 Male Spade terminals (may need to be cut with side cutters if they're too big)
about 2 inch's of speaker wire.
Then what you do:
Strip the rca ends of the cable (being careful not to cut the shield wire around the inner wire)
Crimp a spade terminal on to each channel. (Left and Right)
Then twist the two shield wires together and crimp a terminal on that aswell. (Shield)
Then on each end of the speaker wire crimp a terminal. (Sense & Ground)
From there you simply plug the terminals into the aux plug (behind the fuse box)
I have attached a poorly drawn diagram of what the plug's layout is.
Because both left and right are sheilded individually the sound is fine.
If you need any help on this PM me and ill get back to you as soon as I can :)
Edited by Gymy
