rednose RNS10S Donating Members 2,229 Member For: 18y 6m 24d Gender: Male Posted 05/02/13 02:03 AM Share Posted 05/02/13 02:03 AM (edited) Why can't we only quote part of the previous posters quote? Edited 05/02/13 02:06 AM by rednose Link to comment Share on other sites More sharing options...
rednose RNS10S Donating Members 2,229 Member For: 18y 6m 24d Gender: Male Posted 05/02/13 02:05 AM Share Posted 05/02/13 02:05 AM Just a side note. After my tune many made the assumption that my handy work was a waste of time. The restriction in my car as it sits, is the outlet of the monza cooler, but we were never going to see if my handy work would resulted in a horsepower gain, due to not running at, or beyond the power levels the factory platform is known to achieve. And the fact that the intercooler is the restiction at this point.Easy, give your plenum to Big Al as he is at the limit of the stock one. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 5m 17d Gender: Male Location: Perth Posted 05/02/13 02:05 AM Share Posted 05/02/13 02:05 AM Impellor, did you change injectors when your car was tuned? 2 Link to comment Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 4m 14d Gender: Male Location: Far north queensland Posted 05/02/13 02:06 AM Share Posted 05/02/13 02:06 AM Have you backed this up at the pump or just on theRegardless of the so called experts. The stock plenum can be improved upon. The biggest restriction is in the opening, which is smaller than the T/B outlet. My advice is to smooth the T/B outlet to the same size as the inlet. Then get stuck into the plenum. Firstly, rip a whole heap out of the opening (to match the T/B), and remove a sh*t load out of the curved inlet area, to provide for more flow into 1 and 6. Grind 4-5 mill off the lower casting area, where it flows into the inlet runners. Grind the tumbler openings and smooth. Finally smooth the internals of the tumblers, and plenum.Just a side note. After my tune many made the assumption that my handy work was a waste of time. The restriction in my car as it sits, is the outlet of the monza cooler, but we were never going to see if my handy work would resulted in a horsepower gain, due to not running at, or beyond the power levels the factory platform is known to achieve. And the fact that the intercooler is the restiction at this point.But can anyone explain why I am geting 5.2 litres to the 100km's on flat road in top gear doing 100kph (as opposed to 7.2 pre-tune, always run BP Ultimate). The only thing that I can come up with is efficiency. OK what I have isn't going to win dyno comps, that we all know. But what I do have is a setup that is proving to be ultra efficient at cruising speeds. Which I believe the fuel consumption figures are proving, as they really are the only way to measure an efficiency improvement at this point. Now obviously the tune plays a role through enhanced timing, but I don't believe it is the answer to all the improvement.CheersIs this at the pump or the dash display? Link to comment Share on other sites More sharing options...
BigAl's04 Special needs member. Bronze Donating Members 690 Member For: 14y 6m 6d Gender: Male Location: gold coast Posted 05/02/13 02:11 AM Share Posted 05/02/13 02:11 AM As I've stated before I am quite happy to meet Impellor at RDP and pay for the dyno runs to see what sort of improvements if any have been made. Wouldn't think it would take much longer to swap plenums as it does for him to write his long winded posts. 2 Link to comment Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 8m 4d Gender: Male Location: OZ Posted 05/02/13 02:29 AM Share Posted 05/02/13 02:29 AM I asked you a question a few posts back and am curious to know in which way you found the aftermarket plenum better. .1) Power;2) Visual appeal;3) Economy; and4) Throttle response. 1 Link to comment Share on other sites More sharing options...
rednose RNS10S Donating Members 2,229 Member For: 18y 6m 24d Gender: Male Posted 05/02/13 02:47 AM Share Posted 05/02/13 02:47 AM Thanks Toads Link to comment Share on other sites More sharing options...
Impellor Member 835 Member For: 14y 7m 20d Gender: Not Telling Posted 05/02/13 02:49 AM Share Posted 05/02/13 02:49 AM Knew that was coming. Yes I filled the car and did 86km's making sure never to boost it, or get even close, as the fuel gauge only goes to 99.9 l/100km. So once boosting up the fuel figure isn't accurate. But the instantaneous has always been good. But I needed to be sure. So anyway average fuel usage was at 8.8. Went back and filled it back up cost $12.05 @ $1.589, which was 7.54 litres . that's is actually 8.82 l/100kms. Injectors 60lb Deka's. Cheers Link to comment Share on other sites More sharing options...
freeze_dk I am dissatisfied with my current employment situation Donating Members 8,610 Member For: 18y 5m 12d Gender: Male Posted 05/02/13 02:50 AM Share Posted 05/02/13 02:50 AM I like the FG one as it looks factory, can support 600+rwkw, shortens intake tract and was half the price of Plazmaman etcHow much f*cking around did you have to go through though? I personally like it and would do it if it was a simple changeover.. Link to comment Share on other sites More sharing options...
Impellor Member 835 Member For: 14y 7m 20d Gender: Not Telling Posted 05/02/13 02:53 AM Share Posted 05/02/13 02:53 AM (edited) As I've stated before I am quite happy to meet Impellor at RDP and pay for the dyno runs to see what sort of improvements if any have been made. Wouldn't think it would take much longer to swap plenums as it does for him to write his long winded posts.I tell you what I'll do. I have a plenum here that I could do for you. It would actually be improved on my first attempt. We can go down to see Lee and try it. Now if it doesn't work you can have it . But if it does, and gives you 10% more power, as long as the supporting mods are capable. How much would you be prepared to pay for it? Cheers Edited 05/02/13 02:56 AM by Impellor Link to comment Share on other sites More sharing options...
