Barnesy Donating Members 210 Member For: 16y 4m 30d Gender: Male Location: Brisbane Posted 08/04/13 11:02 PM Share Posted 08/04/13 11:02 PM When you guys are lowering your cars, are you getting front & rear camber kits or just getting the front shimmed and leaving the rear, lets assume SSL all round.? Link to comment https://www.fordxr6turbo.com/forum/topic/83811-g6et-king-lowered-springs/page/5/#findComment-1378777 Share on other sites More sharing options...
JAIH0 Member 5 Member For: 12y 3m 1d Gender: Male Location: Melbourne Posted 09/04/13 02:24 AM Share Posted 09/04/13 02:24 AM What's needed to be done? Is there a tutorial? Link to comment https://www.fordxr6turbo.com/forum/topic/83811-g6et-king-lowered-springs/page/5/#findComment-1378867 Share on other sites More sharing options...
Seaton Donating Members 537 Member For: 12y 9m 24d Gender: Male Location: Sydney Posted 09/04/13 02:32 AM Share Posted 09/04/13 02:32 AM I'm on SSL/SSL combo, had Heasman Steering shim the front. He said no need to do anything with the rear for camber correction. Link to comment https://www.fordxr6turbo.com/forum/topic/83811-g6et-king-lowered-springs/page/5/#findComment-1378869 Share on other sites More sharing options...
JAIH0 Member 5 Member For: 12y 3m 1d Gender: Male Location: Melbourne Posted 09/04/13 03:15 AM Share Posted 09/04/13 03:15 AM That's cool, I bought SSSL's for just the rear for now... Are they easy to do yourself? Do you just release the bottom of the shock and lower the control arm like they do in the Commodores (sorry I had to use that reference!) I'm just curious, because I've come from Holdens all my life... and now I have turned, to the better side Link to comment https://www.fordxr6turbo.com/forum/topic/83811-g6et-king-lowered-springs/page/5/#findComment-1378877 Share on other sites More sharing options...
Bellato Donating Members 2,713 Member For: 14y 8m 1d Posted 09/04/13 04:39 AM Share Posted 09/04/13 04:39 AM sssl's will be border line needing camber adjustment but given it costs a bit of $$ to do it properly don't worry.Yea basically what you said. Undo bottom of shock, undo sway bar and undo control arm at the hub and it'll drop out. Then I put the new spring in and use a trolley jack to jack it back up and put it back togetherAs J@ said, about half an hours work for the rears. I think first time around took me 3hours front and rear and like 1.5-2hours second time around Link to comment https://www.fordxr6turbo.com/forum/topic/83811-g6et-king-lowered-springs/page/5/#findComment-1378901 Share on other sites More sharing options...
JETFPV Donating Members 672 Member For: 17y 7m 15d Gender: Male Posted 09/04/13 04:41 AM Author Share Posted 09/04/13 04:41 AM Barnesy, I have just lowered mine ( SSSL Rear - SSL Front ) and cut my stock rear bumpstop's, no camber correction or anything, drive's straight no pulling, just has a very very faint vibration at around 100k's, might be something to do with the rear driveshaft angle now possibly, anything under 100 there's nothing just around the 100-110k speed's...JAIHO, have to remove front strut assembly to do front's, rear's are like a Holden, just undo the shock's etc and pry the lower control arm down a little to get the spring in...Hope this help's... Link to comment https://www.fordxr6turbo.com/forum/topic/83811-g6et-king-lowered-springs/page/5/#findComment-1378902 Share on other sites More sharing options...
JAIH0 Member 5 Member For: 12y 3m 1d Gender: Male Location: Melbourne Posted 09/04/13 04:42 AM Share Posted 09/04/13 04:42 AM (edited) Okay Awesome, sounds good as! I'll post some pics up of it when I get home tonight which is unmodified, and then on saturday when I get it slightly lowered.Thanks for your help guys, most appreciated! Edited 09/04/13 04:48 AM by JAIH0 Link to comment https://www.fordxr6turbo.com/forum/topic/83811-g6et-king-lowered-springs/page/5/#findComment-1378904 Share on other sites More sharing options...
