Leaking Fuel From Near Injectors/ Fuel Rail?
  • Member For: 12y 5m 1d
Hi guys I got my car back from nizpro last week. the miss's comes in saying my car is leaking. I look underneath sure enough there is a small pool of what looks like fuel? the leak is very high up, but not above the fuel rail. its dropping onto the alternator.
the car went in for hi flow cat. injectors drilled (nizpro recommends), maybe there over drilled and its leaking back down into the intake manifold or something??? any ideas?
I wiped it all clean, took it for a quick spin, put a pan under the car, ill get back to you in a few mins, im thinking it maybe a a leak from one of the bolts near the water pump... is there a common problem with those bolts.
I hope its the injectors as it will be on nizpro. anything else my heap will take the fall :s
Appears to be leaking from the waterpump, ill post a pic up, there is a tapped hole ontop of the water pump, with no bolt in it? could someone have a look at there pump and tell me if they have one there, if not it looks like a seal on the pump itself.
http://imageshack.us/photo/my-images/803/imag0434t.jpg/ picture of the tapped hole ontop of the water pump, possible cause of leak?
keep in mind the car was leaking whilist stationary over night. the to resovoirs either side of the tapped hole were full of oil like substance.
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 7m 20d
Lol that's the a/c compressor haha alternator is the otherside
Bloke smell the fluid
U will know instantly if its fuel
Check the clamps on the rail and check the radiator top hose just incase its coolant
  • Member For: 13y 5m 10d
Firstly start it up and look for the fuel leak!
The fuel will more then likely evaporate overnight anyways so leaving a pan underneath would be useless!
Take a better picture!
If fuel was leaking you should be able to smell it aswell, are you using coolant?
lol my knowledge of cars parts is shinning in this thread. in the photo http://imageshack.us/photo/my-images/803/imag0434t.jpg/ u can see a bolt missing. is there suppose to be one there.
on the underside of the what I thought was a waterpump there was oil. and either side of the hole in the picture in the indented pools there was oil too. but nothing above is leaking.
