myfgturbz Member 102 Member For: 12y 6m 21d Gender: Male Location: Near nizpro Posted 28/01/13 03:35 AM Share Posted 28/01/13 03:35 AM do as above, remove blow off valve, block all hoses that run to the blow off valve with chair stoppers, the vac one im not sure how you go about blocking the small one maybe fold and tape? then go for a drive. gl 1 Link to comment Share on other sites More sharing options...
BigAl's04 Special needs member. Bronze Donating Members 690 Member For: 14y 6m 6d Gender: Male Location: gold coast Posted 28/01/13 05:40 AM Share Posted 28/01/13 05:40 AM Have a good look around the joiner from the crossover to the throttle body. Quite common for them to split. 2 Link to comment Share on other sites More sharing options...
Rddrgn Member 8 Member For: 12y 1m 19d Posted 31/01/13 11:51 AM Author Share Posted 31/01/13 11:51 AM Hey guys,Thanks for the feedback. I did everything you guys proposed. In the end it was the Crossover (3 Inch to 3 Inch Connector)That conects to the throttle body. Half of the lip on the throttle body side split.My solution. I put in Blue Slicone Pipes and Decent Pipe Crimps with a Hex Bolt to tighten that don't snap.Only problem is I have moved the crossover aluminium piping on top of the engine. and until tomorrow my vacuum to the BOV is disconnected as it is to short.The reason I moved everything over a lil is to prevent blowouts.The Difference in performance. Well it use to perform like my standard 304 5 L VT Clubsport. when it was standard.Now it performs like well I sh*t my pants =) And thankyou for all your help. I also did the soleoid maintanance (Didn't do anything) I'm a bit worried nowI might have sucked up some crap with the hole in the connecter to the intake.Also I have a set of Coil Packs to replace (Original VDO) which will happen very soon as I bought them thinking it was what was wrong.But I get a BRRRRT and low power between 2800rpm-3200 rpm so I believe at 150000km its time to do it for good measureOk so guys for the next two days unfortuantely I can't reconnect the vacuum line to the BOV until im off work. Will 300-400km of driving without the vacuumline connected to the bov and it just free floating cause any damage. And also is my Turbo Glowing a light Red after a solid 10 min thrash fest for about 2-3 minutes when I park and let it idle normal? Im worried the filter might be blocked which feeds oil. I would rather remove the filter and just have a straight through line as I have an engine oil filter that should do all the work anyway.Ok guys . I'm officially converted to ford. Still a lil Expensive Daewoo fan because of my 383 stroker weekend car. But fark this xr6 turbo is nuts and its stock apart from a farty blarty sh*t exhaust someone fitted without a tune. Not bad got the car for $7900. Fark all great nick inside. engine bay looks new and the outside well needs a lil buf and the front and rear bars resprayed for $600 oh well at least they will be new Link to comment Share on other sites More sharing options...
Kosij Donating Members 2,045 Member For: 13y 7m 1d Gender: Male Posted 31/01/13 12:16 PM Share Posted 31/01/13 12:16 PM Coils + VDO are sh*t go to ford and get genuine ones around $250Turbo glowing red is normal the snail pumps hard lolOil line remove it and fit a earls inline filter that way there's no chance of starvation! BOV- I THINK no vacuum line will let it open therefore boost wont be held! Someone more smarter shoot me down if I'm wrong lolFORD VS HOLDEN! FARK Expensive Daewoo LOL you will be turned 100% after a few little mods! Link to comment Share on other sites More sharing options...
Rddrgn Member 8 Member For: 12y 1m 19d Posted 01/02/13 02:05 AM Author Share Posted 01/02/13 02:05 AM The ford genuine are vdo from what I saw Link to comment Share on other sites More sharing options...
boost69 Donating Members 737 Member For: 19y 9m 21d Posted 01/02/13 02:22 AM Share Posted 01/02/13 02:22 AM I rung up a Ford Dealer today and was quoted $81.60 per coil.Is anyone getting Genuine ones cheaper? Link to comment Share on other sites More sharing options...
MY ROD GOT OUT Member 434 Member For: 14y 6m 8d Posted 01/02/13 06:19 AM Share Posted 01/02/13 06:19 AM Got mine for $200 delivered. "mikesmodelcars" on eBay (have to search his name cause he doesn't sell online anymore I don't think) and comes with a receipt from Coffey ford Link to comment Share on other sites More sharing options...
Kosij Donating Members 2,045 Member For: 13y 7m 1d Gender: Male Posted 01/02/13 07:55 AM Share Posted 01/02/13 07:55 AM The ford genuine are vdo from what I sawNO Link to comment Share on other sites More sharing options...
