  • RNS10S
  • Member For: 18y 8m
  On 07/02/2013 at 5:57 AM, Kosij said:
Hmmm phone is jail broken. Never thought of looking there lol
Dash Command works well but no trans temp.
  • Member For: 12y 6m 7d
  On 07/02/2013 at 5:13 AM, bjc said:
6sp auto does have temp sensor.
Found an extra which will be the fluid temp-
For the Editor-
-PID:221674
-Min:0.0
-Max:100.0
-Scale: x1
-Unit type:(Insert Degree symbol)F
-Equation: ((A*256)+B)/8
-Header: Auto
Hmmm..gives me 383°F which is 195°C on my G6ET, while coolant temp is 80°C
  • skids
  • Member For: 12y 3m 19d
  • Gender: Not Telling
This might sound crazy, but wouldnt somebody be able to create a bluetooth adaptor for next to nothing that connects to your phone and allows you to flashtune your car?
Like honestly myself - I would always go to a professional tuner and get the job done right, but this idea applies for changing tunes as well?
The only way I can see this might have an issue is if there is some secret code that only the makers of the expensive flash tuners know (they are expensive for a reason I would think).
(I am not saying flash tuners are a rip off, they are something you need to extract more power from these cars properly I believe.. One of the best value for money mods).
  • RNS10S
  On 07/02/2013 at 6:57 AM, Kosij said:
Tyred searching cydia, couldn't find it :/
You cannot download dashcommand in Cydia, but Cydia is where you add the repository to access the software to download the cracked apps.
There was installous which has stopped working, then appcake stopped working so I have found this one, enjoy.
  • RNS10S
Not sure if has been released in the states yet, cause I never ended up following up on it, but SCT were releasing an app for iDevices that allowed to switch tunes through a wireless obd2 connector.
Maybe have a look at SCT's website, but not sure if it would be compatible with the aussie sct, maybe Herrod would know
  • Member For: 14y 3m 7d
that's called pirating and is bad :P you can get bluetooth drivers from cydia somewhere, should be tonnes of how-tos on it,.
