Hotwire Donating Members 172 Member For: 16y 8m 19d Gender: Male Location: Adelaide Posted 07/02/13 05:11 AM Share Posted 07/02/13 05:11 AM Trans fluid temp PID: 221674The 221674 is for TFT from a ZF Transmission, which is a separate module. So instead of sending the request to the PCM at 7E0 the request is sent to the TCM at 7E1. No use for you on a BA with PCM-controlled 4Spd though. Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/page/7/#findComment-1359910 Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 9m 29d Gender: Male Location: Townsville Posted 07/02/13 05:13 AM Share Posted 07/02/13 05:13 AM I've been researching what the address is for the BA and can't find it :(4sp Auto doesn't have one. 6sp auto does have temp sensor.Found an extra which will be the fluid temp-For the Editor--PID:221674-Min:0.0-Max:100.0-Scale: x1-Unit type:(Insert Degree symbol)F-Equation: ((A*256)+B)/8-Header: AutoAs I said in my previous post on page 1 My car is a 09 F6X (turbo territory) though with the 6 speed auto Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/page/7/#findComment-1359911 Share on other sites More sharing options...
Hotwire Donating Members 172 Member For: 16y 8m 19d Gender: Male Location: Adelaide Posted 07/02/13 05:18 AM Share Posted 07/02/13 05:18 AM When consulting the BA manual, the 4speed auto definitely does have a Temp Sensor.Connects at pins A37 & A32 on the PCM, has a resistance range from 3800ohm (10ºc) to 110ohm (120º) and is used in calculation of transmission control parameters. So it must be there, its just a matter of identifying the PID it utilises.Transmission InputsTransmission Fluid Temperature SensorThe Transmission Fluid Temperature (TFT) sensor islocated in a harness within the AutomaticTransmission oil pan. The TFT measures thetemperature of the oil in the automatic transmissionsump. The Powertrain Control Module (PCM) usesthe TFT signal to vary shift pressures in response tothe transmission oil temperature for consistent andsmooth shifts. It is also used to indicate transmissionoverheat conditions.The TFT sensor uses a thermistor that is sensitive totemperature variations. The resistance of thethermistor decreases as the temperature of thetransmission oil increases. Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/page/7/#findComment-1359913 Share on other sites More sharing options...
Bulletime Donating Members 937 Member For: 14y 5m 24d Gender: Male Posted 07/02/13 05:20 AM Share Posted 07/02/13 05:20 AM I have borrowed my Nieces Android tablet and purchased Torque - so mucking around with it at present to see what I can/can't access. when adding the Ford PID's, it seems to add only those published in the link I just sent - so it seems the developer of Torque had no more access to Ford PID's ufortunately. That being said, Palmer (who created Dashcommand) have a HUGE list of Ford specific PID's, as I have in their SCAN XL software, BUT They dont and wont publish the addresses for them. I presume they paid big $$ for them, as they charge extra for the Ford PID's to be included. That being said, its pretty piss poor they dont include them in the dashcommand software as its not a cheap app!very f*cking piss poor! It's a bloody expensive app! Maybe we need to email spam them and get it added. I really want trans temp and it should be accessible. Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/page/7/#findComment-1359914 Share on other sites More sharing options...
Kosij Donating Members 2,045 Member For: 13y 10m 23d Gender: Male Posted 07/02/13 05:30 AM Share Posted 07/02/13 05:30 AM So I've bought that $18.99 bluetooth unit!I have a iPhone is dash command the best app for me? I don't own any android items! Or would I be best buying a $100 tablet? Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/page/7/#findComment-1359919 Share on other sites More sharing options...
Bulletime Donating Members 937 Member For: 14y 5m 24d Gender: Male Posted 07/02/13 05:33 AM Share Posted 07/02/13 05:33 AM Well DashCommand is awesome except that it doesn't do trans temp, as it appears neither does anything on iPhone, and I don't own any androids (or cyborgs) either. Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/page/7/#findComment-1359921 Share on other sites More sharing options...
Kosij Donating Members 2,045 Member For: 13y 10m 23d Gender: Male Posted 07/02/13 05:37 AM Share Posted 07/02/13 05:37 AM Have a btr4spd didn't think trans temp was available anyways! Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/page/7/#findComment-1359924 Share on other sites More sharing options...
Bulletime Donating Members 937 Member For: 14y 5m 24d Gender: Male Posted 07/02/13 05:45 AM Share Posted 07/02/13 05:45 AM My bad. DashCommand is cool though. Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/page/7/#findComment-1359925 Share on other sites More sharing options...
Kosij Donating Members 2,045 Member For: 13y 10m 23d Gender: Male Posted 07/02/13 05:46 AM Share Posted 07/02/13 05:46 AM Worth the $50 or best to spend $100 on a roid tablet? Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/page/7/#findComment-1359928 Share on other sites More sharing options...
Hotwire Donating Members 172 Member For: 16y 8m 19d Gender: Male Location: Adelaide Posted 07/02/13 05:51 AM Share Posted 07/02/13 05:51 AM Pretty certain the $18 Bluetooth unit won't work with your iPhone as the haven't paid for apple Bluetooth stack protocol info. Buy a $100 android tablet for the car. That's what I'll be doing when my niece wants hers back Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/page/7/#findComment-1359929 Share on other sites More sharing options...
