JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 10m 21d Gender: Male Location: Adelaide Posted 29/05/13 10:12 PM Share Posted 29/05/13 10:12 PM Yep works spot on ( selecting tcm ) but my front mount zf cooler keeps my temps down quite well Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/page/15/#findComment-1394024 Share on other sites More sharing options...
vxr50t Member 134 Member For: 12y 10d Posted 29/05/13 11:14 PM Share Posted 29/05/13 11:14 PM Sorry haven't updated for a while. Yeah the tcm does the trick it reads in celcius after I rebooted my phoneSent from my GT-I9300 using Motorculture mobile app Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/page/15/#findComment-1394035 Share on other sites More sharing options...
ccpl Member 17 Member For: 12y 6m 7d Posted 30/05/13 03:55 AM Share Posted 30/05/13 03:55 AM Yep works spot on ( selecting tcm ) but my front mount zf cooler keeps my temps down quite wellWhat temps are you getting?Mine (also with front mount ZF cooler) seems to hover around 40-50 degrees for normal driving. Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/page/15/#findComment-1394142 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 10m 21d Gender: Male Location: Adelaide Posted 30/05/13 04:48 AM Share Posted 30/05/13 04:48 AM Yep between 40-50 Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/page/15/#findComment-1394168 Share on other sites More sharing options...
Hotwire Donating Members 172 Member For: 16y 6m 8d Gender: Male Location: Adelaide Posted 31/05/13 02:28 AM Share Posted 31/05/13 02:28 AM I have the radiator bypassed on my BTR 4 speed to external cooler, and often see temps of 40-50º with a max of around 75º. However, what concerns me is that if you look at the viscosity specs of trans fluid, e.g. penrite stuff: http://www.penriteoil.com.au/pis_pdfs/0ATF%2095LE.pdf The viscosity at 40º is 46, whereas the ford defined operating temperature (nearing 100ºc) is 8.3. Therefore with our trans running so cold, would the internals not be working harder to move the trans fluid around? Thoughts? Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/page/15/#findComment-1394393 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 10m 21d Gender: Male Location: Adelaide Posted 31/05/13 05:18 AM Share Posted 31/05/13 05:18 AM Hard to say but in theory yesBut 90% of transmission failures are due to over heated oil / burnt out oil Ive always run a front mounted trans cooler on my falcons and had above average trans life and performance Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/page/15/#findComment-1394447 Share on other sites More sharing options...
Spyathe Donating Members 872 Member For: 11y 5m 23d Gender: Male Posted 03/12/13 11:21 AM Share Posted 03/12/13 11:21 AM (edited) Finally got the trans temp to work!! Thank you soo much Sorry for the thread revival Now to hunt for engine temp/pressure Edited 03/12/13 11:23 AM by Spyathe Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/page/15/#findComment-1443700 Share on other sites More sharing options...
Lunchietey Member 84 Member For: 14y 8m 18d Gender: Male Location: WA Posted 20/05/17 10:53 AM Share Posted 20/05/17 10:53 AM On 2013-5-22 at 6:41 AM, Hotwire said: I have trans temp working for the BTR 4 sp!! After much trawling the Internet and trial and error I now have trans temp for the BTR to be able to be monitored via Torque: PID: 22092C Scale Factor: x1 Equation: (((A*256)+B)-32)*5/9 Header: <-- Blank Did this today. Have been using Torque Pro for quite a while now on multiple cars. Thankyou for posting this. I know it's an old post but was the first I found with the right PID Worked perfectly and temp tracked exactly as expected. Sat near 80 degC once it had stabilised on my BA wagon. External cooler(rad bypass) and flush Monday so will do a comparison temp and post it here. Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/page/15/#findComment-1639477 Share on other sites More sharing options...
Lunchietey Member 84 Member For: 14y 8m 18d Gender: Male Location: WA Posted 22/05/17 11:19 PM Share Posted 22/05/17 11:19 PM Significant drop in temp. This was after a fairly long drive of all mixed driving. Noice 1 Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/page/15/#findComment-1639675 Share on other sites More sharing options...
rednose RNS10S Donating Members 2,229 Member For: 18y 8m 5d Gender: Male Posted 05/09/19 12:07 AM Share Posted 05/09/19 12:07 AM Thread revival..... OBD Fusion is available for IOS and it does Trans Fluid Temp Similar settings as the Torque app Currently only showing in F not C but I'm sure it can be changed in the settings, I'll have a play when I get a chance 1 Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/page/15/#findComment-1688132 Share on other sites More sharing options...
