mrxd Member 74 Member For: 12y 7m 14d Gender: Male Posted 15/02/13 11:18 AM Share Posted 15/02/13 11:18 AM Depends on your keyboard, on a nexus 4 running android 4.2.2 you tap '?123' then '=<' and you'll then see '°'. Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/page/12/#findComment-1363215 Share on other sites More sharing options...
azz80 Donating Members 76 Member For: 20y 4m 12d Gender: Male Location: Brisbane Posted 15/02/13 08:44 PM Share Posted 15/02/13 08:44 PM On 15/02/2013 at 10:08 AM, welshy_89 said: How do u set degrees celcius or farenheit as I can't do the little circle with my fone for the degrees. Also wats everyone's readings mine seems to be around 82' celcius at idle and cruising around.. that's with an external cooler thoughI only started using torque the other day and in half hour city driving my reading was ~88 with std zf.Also, is there any other way of recording oil pressure without using in-car gauge & adaptor plate? Doesn't look like its on the list of sensors. Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/page/12/#findComment-1363263 Share on other sites More sharing options...
welshy_89 Member 131 Member For: 13y 9m 28d Posted 15/02/13 08:57 PM Share Posted 15/02/13 08:57 PM I don't think the ford pcm has a oil psi gauge as such I think.as long as it sees something the pcm is happy... Cld be wrong though Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/page/12/#findComment-1363270 Share on other sites More sharing options...
mrxd Member 74 Member For: 12y 7m 14d Gender: Male Posted 15/02/13 10:29 PM Share Posted 15/02/13 10:29 PM For those of you with working trans temp, any FG's or mostly BA/BF ? Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/page/12/#findComment-1363286 Share on other sites More sharing options...
SuckSqueezeBangBlow ʎǝʞuoɯ ɹoıuǝs Donating Members 1,808 Member For: 16y 5m 7d Gender: Male Posted 15/02/13 10:59 PM Share Posted 15/02/13 10:59 PM Another plug for aeroforce interceptor:U can add wideband and oil temp/pressure sensor inputs too.Not sure ill ever need steering wheel angle or tps numbers in my face so will just stick with what ive got Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/page/12/#findComment-1363296 Share on other sites More sharing options...
Panda Eyes flame magnet Gold Donating Members 5,674 Member For: 17y 7d Gender: Male Location: adelaide hills- 'race air' central Posted 16/02/13 12:51 AM Share Posted 16/02/13 12:51 AM I just got the torque pro app for my htc 0ne x: $4.95normal size obd2 bluetooth interface: $10.40 from china (where else).will wait a couple weeks to get it then report back... Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/page/12/#findComment-1363329 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 5m 28d Gender: Male Location: Probably above atmospheric pressure Posted 20/02/13 03:35 AM Share Posted 20/02/13 03:35 AM Having a play myself with this today, as Spook corrected himself I found using the ZF temp reading "Transmision Temperature(Method 1)" works on my BF, I tried the custom entry (PID 221674) listed earlier but it had no reading at all.The predefined list of "custom Ford PIDs" shows "Transmission Fluid Temp" as PID 221674 with the same settings Spook gave originally, but it lists it as °F not °C with that equation.Haven't gone for a drive and logged anything yet though only idled in garage a couple of minutes.Best $25 I've spent (app plus dongle). See how long the dongle lives Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/page/12/#findComment-1364688 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 22d Gender: Male Location: Adelaide Posted 20/02/13 04:18 AM Share Posted 20/02/13 04:18 AM What dongle did u get steve Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/page/12/#findComment-1364705 Share on other sites More sharing options...
Hotwire Donating Members 172 Member For: 16y 7m 9d Gender: Male Location: Adelaide Posted 20/02/13 04:55 AM Share Posted 20/02/13 04:55 AM On 20/02/2013 at 3:35 AM, -SteveR- said: Having a play myself with this today, as Spook corrected himself I found using the ZF temp reading "Transmision Temperature(Method 1)" works on my BF, I tried the custom entry (PID 221674) listed earlier but it had no reading at all.The predefined list of "custom Ford PIDs" shows "Transmission Fluid Temp" as PID 221674 with the same settings Spook gave originally, but it lists it as °F not °C with that equation.Haven't gone for a drive and logged anything yet though only idled in garage a couple of minutes.Best $25 I've spent (app plus dongle). See how long the dongle lives The custom PID didnt work (most likely) as you left the header as Auto, which looks to the PCM. You need the correct header to point it to the TCM, which Trans Temp Method 1 gives Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/page/12/#findComment-1364712 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 5m 28d Gender: Male Location: Probably above atmospheric pressure Posted 20/02/13 06:23 AM Share Posted 20/02/13 06:23 AM I see! That explains it.I got this dongle as recommended earlier in the thread as the best of the cheapies I thinkhttp://www.ebay.com.au/itm/120998879838?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649 Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/page/12/#findComment-1364735 Share on other sites More sharing options...
