crazyxa Member 84 Member For: 18y 2m 7d Posted 25/01/13 01:56 AM Share Posted 25/01/13 01:56 AM Hi has anyone been successful in using an OBDII scanner and an iphone app to monitor ZF trans temp on an FG?If so can you post what hardware and software you are using and approx cost. Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/ Share on other sites More sharing options...
HYPEDF6 Donating Members 301 Member For: 12y 5m 10d Gender: Male Posted 25/01/13 02:00 AM Share Posted 25/01/13 02:00 AM Have you fired up the weekend crack pipe early or can this seriously be done ?Im going to be f*cking stoked if you not on the pipe. Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/#findComment-1354452 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 18d Gender: Male Location: Adelaide Posted 25/01/13 02:15 AM Share Posted 25/01/13 02:15 AM Yes u can with the torque app for ( android ) and the rev for iphone The torque app is better than rev imhoThe apps are free but the better ones are a few bucks Hardware wise go these The iphone one is by far the most expensive at nearly $60 Asaik the generic bluetooth ones for android are cheap and not compatiable with the " iphone dongle " Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/#findComment-1354457 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 18d Gender: Male Location: Adelaide Posted 25/01/13 02:17 AM Share Posted 25/01/13 02:17 AM Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/#findComment-1354459 Share on other sites More sharing options...
HYPEDF6 Donating Members 301 Member For: 12y 5m 10d Gender: Male Posted 25/01/13 02:17 AM Share Posted 25/01/13 02:17 AM Now im erect. 2 Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/#findComment-1354460 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 18d Gender: Male Location: Adelaide Posted 25/01/13 02:18 AM Share Posted 25/01/13 02:18 AM Piks ? Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/#findComment-1354462 Share on other sites More sharing options...
HYPEDF6 Donating Members 301 Member For: 12y 5m 10d Gender: Male Posted 25/01/13 02:30 AM Share Posted 25/01/13 02:30 AM (edited) Cheers.Cheers.Cheers. Needs more cheers in here. Also my wallet is lighter $60 cause of this thread but cheers. Edited 25/01/13 02:32 AM by HYPEDF6 Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/#findComment-1354466 Share on other sites More sharing options...
XtRmn8 570Nm @1800rpm Donating Members 2,441 Member For: 21y 7m 27d Gender: Male Location: Perth, WA Posted 25/01/13 03:10 AM Share Posted 25/01/13 03:10 AM (edited) Lot of info in this thread over at AFF http://fordforums.com.au/showthread.php?t=11326889&highlight=OBDIIAs Jet said the Android App is a lot better than the iPoo one. Also there is now a new "slim" version of the ELM327 OBDII dongle that will allow you to put the fuse box cover back on and they are about $15. Assuming you have an Android smartphone you can be in business for about $20 including the paid app and dongle Software (Android)Free version of Torque: https://play.google.com/store/apps/details?id=org.prowl.torquefree&feature=search_resultPaid version of Torque: https://play.google.com/store/apps/details?id=org.prowl.torque&feature=search_resultHardware (Android)http://www.ebay.com.au/itm/MINI-Smallest-ELM327-Bluetooth-V1-5-OBD2-OBDII-Car-Diagnostic-Scanner-Adapter-/121046956689?pt=AU_Car_Parts_Accessories&hash=item1c2ef5fa91&_uhb=1#ht_3386wt_1163http://www.ebay.com.au/itm/Real-Smallest-ELM327-V1-5-Bluetooth-OBD2-OBDII-Car-Auto-Diagnostic-Scanner-Tool-/360554317758?pt=AU_Car_Parts_Accessories&hash=item53f2b647be&_uhb=1#ht_50wt_1397 Edited 25/01/13 03:12 AM by XtRmn8 Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/#findComment-1354474 Share on other sites More sharing options...
Bulletime Donating Members 937 Member For: 14y 4m 10d Gender: Male Posted 25/01/13 03:14 AM Share Posted 25/01/13 03:14 AM I've got an obd2 Bluetooth thingy it was a bit over $100 from the us, works android or iPhone and the DashCommand app in iOS. Also have ram mount setup to mount my iPhone to the dash, prob about ~$40ish there. I haven't seen trans temp available unless its a custom code from our ecus?? There's boost, map, intake temp coolant temp, fuel trip timing advance fuel flow rpm and speed. One of the kiwi wifi obds has an input from other sensors so you could theoretically plug in some trans temp sensor and read that. But yeah if there's a code for the trans temp I'd be cheering to get it!!! Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/#findComment-1354476 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 18d Gender: Male Location: Adelaide Posted 25/01/13 03:15 AM Share Posted 25/01/13 03:15 AM The slimline one for $15 is junk unfortunately been there done that The obd2 port can un clip and house the big dongle and pop the cover back on anyways Link to comment https://www.fordxr6turbo.com/forum/topic/83743-montoring-trans-temp-with-iphone/#findComment-1354478 Share on other sites More sharing options...
