  • Member For: 14y 6m 11d
hi guys ive recently had my zf service for the first time. cars a 06 BF2 done 77000km. reason for servicing it is it was slowly incresing in slip and gear changes when cold (runs fine when hot). after the service it hasnt improved at all. infact the other day on my way to work the trans was flippin out while I was just babying it while still cold. didnt know what gear it should be in and the trans ended up going into limp mode and stuck in 3rd gear. had to pull over and restart the car to clear it.
ive had a tune done on the car (345rwkw) as well as the zf tune about 3 years ago and has been running fine but slowly the problem has been getting worse. out of curiosity I flashed my tune up that is the same with no trans tune (as standard) and seems to have improved it cold changes.
has anyone else experience this? would it be an indication of box needing a rebuild? I would have thought I'd get more than 77K out of it??
https://www.fordxr6turbo.com/forum/topic/83730-zf-standard-vs-tuned/
  • Member For: 17y 29d
Zf tune 3 years ago?
Time machine?
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 10m 18d
Lol
Two weeks .....
Bloke who tuned it
I think I know where this is going
Theres a difference between " zf tune " and old style calibrations
Check your coolant over flow for " milkshake"
What oil and filter was used on service ?
Who done it ?
Oh ok. Mv automatics done the service. Genuine oils used. Changed to the steel pan and filter. Was doing it before the service too. No milkshake. Would you recommend just running it on the standard tune then?
I recomend u take it back to mv and get them to check the fluid level first
If everythings fine tack it to bruce he will happily look at it for u
  • Member For: 16y 4m 10d
I think there was a bloke on her didn't have zf tuned for the first few years of owning his car then went to zf tune and drove it for a while, then decided he wanted to go back to stock zf and the box hated it. Drove really weird and flared ect, something to do with different clutch pack wear maybe? just saying it may get worse...
  • Member For: 17y 4m 25d
Yep I recall that thread, not too long ago.
