GeGe6 Donating Members 1,980 Member For: 12y 9m 24d Gender: Male Location: Perth, SOR Posted 23/01/13 02:17 PM Share Posted 23/01/13 02:17 PM (edited) Hey Fellas, Just a bit of an in site into replacing smashed fog light housing. I hunted around and got varying quotes. Fraud at $210.00 surprise surprise. Coventry $140.00 (fit myself) eBay seller $45.00 I took the eBay option. Quality of the housing was good and came with Osram globe. First step full lock wheels to gain access To fog light by removing forward lower wheel arch plastic. Disconnect wiring from fog light housing and move aside. Globe to if you wish. There are three Phillips head screws holding housing in place undo and remove the housing. A light inside the front bar helps at this stage. Install new housing. Place globe in housing, connect up wiring and place plastic cover back on wheel arch. With the $150 plus dollars I saved from not getting the Fraud dealer to do it, I ventured out and got sum head light protection film from Supercheap $30 I applied to both fog lights to prevent breakage from stones etc (or try to stop). Pics as follows; I cut the film just slightly bigger so edges of film is hidden by fog light bar surrounds. Spay fog light with detergent mixed at 2% strength and place film onto fog light . I found using a stiff piece of cardboard was good tool for pushing out air bubbles as it contoured well on the curved surface. The key to a good job was while working out the bubbles use a hair dryer to heat the film, moulding it to the lens. Finished job below. All in all an easy job with fog light replacement taking 20mins give or take and film about 30-45mins. Hope it helps. Cheers. Edited 23/01/13 02:26 PM by GeGe6 1 Link to comment https://www.fordxr6turbo.com/forum/topic/83721-g6e-fog-light-replacement-and-protective-film/ Share on other sites More sharing options...
GeGe6 Donating Members 1,980 Member For: 12y 9m 24d Gender: Male Location: Perth, SOR Posted 23/01/13 02:30 PM Author Share Posted 23/01/13 02:30 PM ^^Not sure why these images didn't go on! 1 Link to comment https://www.fordxr6turbo.com/forum/topic/83721-g6e-fog-light-replacement-and-protective-film/#findComment-1353808 Share on other sites More sharing options...
Xr50 Donating Members 196 Member For: 14y 10m 10d Gender: Male Location: Brisbane Posted 24/09/13 03:52 AM Share Posted 24/09/13 03:52 AM thanks for that, made removing the fog light assembly look easy as. Gonna take mine out this weekend and give em a clean up. Link to comment https://www.fordxr6turbo.com/forum/topic/83721-g6e-fog-light-replacement-and-protective-film/#findComment-1427565 Share on other sites More sharing options...
[THOMMO] Member 94 Member For: 8y 10m 15d Posted 19/02/17 02:36 PM Share Posted 19/02/17 02:36 PM Just what I'm looking for! Does anyone know if the fpv fg fog lights are the same, they seem to look the same?? Link to comment https://www.fordxr6turbo.com/forum/topic/83721-g6e-fog-light-replacement-and-protective-film/#findComment-1632283 Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 13y 5m 1d Gender: Male Location: WA, Perth Posted 19/02/17 03:09 PM Share Posted 19/02/17 03:09 PM That was a good I am not sure if the members in this thread have been on recently. Hopefully someone else can answer this for ya. Link to comment https://www.fordxr6turbo.com/forum/topic/83721-g6e-fog-light-replacement-and-protective-film/#findComment-1632286 Share on other sites More sharing options...
