Spinning Donating Members 348 Member For: 15y 10m 9d Posted 23/01/13 10:53 AM Share Posted 23/01/13 10:53 AM Having left the dealership , I had the opportunity to talk to the service manager , and I stated I would be back to have the oil changed at 1000k and then at intervals of 5000k .. He looked me up and down like I was from outer space or had just jumped out from under a rock.. I stated ,it has been a practice I have employed with all my cars . He stated he wouldn't and would look to change the oil at no less than 7000ks ..as it had special oil designed to help the engine in the early stages .. I said , that ' s ok , just replace it with the special oil at 1000 and again at 5000. Would hear of it....Is there any truth / merit in this special oil? Am I wrong to change it at 1000 and then at intervals of 5000? Link to comment https://www.fordxr6turbo.com/forum/topic/83714-first-oil-change-at-1000ks/ Share on other sites More sharing options...
damo6 Member 85 Member For: 12y 3m 22d Gender: Male Location: brisbane nth Posted 23/01/13 10:59 AM Share Posted 23/01/13 10:59 AM im in the same boat as you spinning and was told the same by my dealer as well.reckons prematurely changing the "running in oil" may affect the bores as in glazing etc.. crap I reckon but just the same id like to know as well Link to comment https://www.fordxr6turbo.com/forum/topic/83714-first-oil-change-at-1000ks/#findComment-1353695 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 11m 8d Gender: Male Location: @ my laptop Posted 23/01/13 11:16 AM Share Posted 23/01/13 11:16 AM (edited) it is a good idea to change oil and filter early and in some cases there is a different oil that is required until the car has done approx 15000 klms Edited 24/01/13 01:43 AM by ratter 1 Link to comment https://www.fordxr6turbo.com/forum/topic/83714-first-oil-change-at-1000ks/#findComment-1353711 Share on other sites More sharing options...
Spinning Donating Members 348 Member For: 15y 10m 9d Posted 23/01/13 08:28 PM Author Share Posted 23/01/13 08:28 PM I see ... There is a 'special' oil ..Having said that - I am still of the opinion that no harm - except good can only come from altering the oil early and having it replaced with the same 'special' oil at least until 10,000k - which will mean that I will have changed the oil already twice - once at 1000k and then at 5000k . I am not confident that the service manager will not allow me to change the oil - he already thinks I am a nutter .. Should I then take the car elsewhere to have the oil and filter changed ? - Where ? Link to comment https://www.fordxr6turbo.com/forum/topic/83714-first-oil-change-at-1000ks/#findComment-1353835 Share on other sites More sharing options...
Never had any say Panda I <3 Floods Silver Donating Members 11,198 Member For: 13y 9m 4d Gender: Male Location: South West QLD Posted 23/01/13 09:26 PM Share Posted 23/01/13 09:26 PM I'm curious as to what sort of oil should be run also.. Link to comment https://www.fordxr6turbo.com/forum/topic/83714-first-oil-change-at-1000ks/#findComment-1353859 Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 13y 9m 8d Gender: Male Posted 23/01/13 09:33 PM Share Posted 23/01/13 09:33 PM Im in two minds about this, YES they are factory filled with a run in oil. Changing it at 1-3000ks if it was my car I would just leave the run in oil in until 5000. BUT I dont think any damage will be done changing it at 1000, as anyone with a freshly built (although slightly higher tolerance) performance engine would do. Oil changes every 5000ks are the go as the factory 15k intervals are a stretch and a half! 1 Link to comment https://www.fordxr6turbo.com/forum/topic/83714-first-oil-change-at-1000ks/#findComment-1353863 Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 3m 17d Gender: Male Location: Christchurch, New Zealand Posted 24/01/13 01:39 AM Share Posted 24/01/13 01:39 AM I don't see any issue with what your asking to be done, if you want to spend the money and have it changed more often that's fine. Just stick with the run in oil till the time that your meant to change to normal syn oil that way it won't affect the warranty on the vehicle.I personally do 7500ks between oil changes but would never go 15000 like the factory states. Link to comment https://www.fordxr6turbo.com/forum/topic/83714-first-oil-change-at-1000ks/#findComment-1353958 Share on other sites More sharing options...
Bulletime Donating Members 937 Member For: 14y 3m 26d Gender: Male Posted 24/01/13 09:03 AM Share Posted 24/01/13 09:03 AM I feel dirty knowing I got to 45k kms before I started more regular intervals, thing that eases it a bit is that most of my kms are cruising speed so hopefully that makes it not 'as' bad. If you have the time drop the oil yourself, simple as, rewarding too. Link to comment https://www.fordxr6turbo.com/forum/topic/83714-first-oil-change-at-1000ks/#findComment-1354153 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 11m 8d Gender: Male Location: @ my laptop Posted 24/01/13 09:07 AM Share Posted 24/01/13 09:07 AM lack of servicing at any point can lead to the formation of sluge in the engine that can not be removed and restricts oil galleries etc 1 Link to comment https://www.fordxr6turbo.com/forum/topic/83714-first-oil-change-at-1000ks/#findComment-1354156 Share on other sites More sharing options...
Benny Member 1,869 Member For: 21y 8m 29d Gender: Male Location: Newcastle Posted 24/01/13 09:12 AM Share Posted 24/01/13 09:12 AM I'd like to know what information is there that tells people that "run in" oil is used in the Falcon. If there is then what is the difference between that and the normal oil. Benny. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/83714-first-oil-change-at-1000ks/#findComment-1354166 Share on other sites More sharing options...
