ratter Member 6,793 Member For: 18y 11m 2d Gender: Male Location: @ my laptop Posted 25/01/13 11:47 AM Share Posted 25/01/13 11:47 AM when we order the columns from ford, they need to know the vin to match the correct column as there are different ones for the same model car Link to comment https://www.fordxr6turbo.com/forum/topic/83669-bf-ignition-barrel-problem-need-help/page/4/#findComment-1354736 Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 13y 9m 2d Gender: Male Posted 25/01/13 11:49 AM Share Posted 25/01/13 11:49 AM Yep, either u have the wrong column, something isnt plugged in, batterys flat or a fuse is blown, in that order... Link to comment https://www.fordxr6turbo.com/forum/topic/83669-bf-ignition-barrel-problem-need-help/page/4/#findComment-1354739 Share on other sites More sharing options...
jim985 Member 76 Member For: 16y 23d Gender: Male Location: Hunter Valley, NSW Posted 25/01/13 12:51 PM Author Share Posted 25/01/13 12:51 PM I will pull the column back out and carefully check the wires that came with it. I guess I could splice in the original wires, except for the ones connected to the ignition.I will charge the battery and check the fuses also. Hope this works.Thanks for all the help guys. Link to comment https://www.fordxr6turbo.com/forum/topic/83669-bf-ignition-barrel-problem-need-help/page/4/#findComment-1354759 Share on other sites More sharing options...
jim985 Member 76 Member For: 16y 23d Gender: Male Location: Hunter Valley, NSW Posted 01/02/13 02:05 AM Author Share Posted 01/02/13 02:05 AM Turned out that a fuse was blown.All good now. Thanks for all the help guys. Link to comment https://www.fordxr6turbo.com/forum/topic/83669-bf-ignition-barrel-problem-need-help/page/4/#findComment-1357047 Share on other sites More sharing options...
Kosij Donating Members 2,045 Member For: 13y 8m 19d Gender: Male Posted 05/02/13 03:35 AM Share Posted 05/02/13 03:35 AM What fuse Link to comment https://www.fordxr6turbo.com/forum/topic/83669-bf-ignition-barrel-problem-need-help/page/4/#findComment-1358890 Share on other sites More sharing options...
alizasoain8 New Member 3 Member For: 11y 11m 27d Posted 24/05/13 09:33 AM Share Posted 24/05/13 09:33 AM G,day all.I am new to all this so please excuse my noobness.Stupid question, but why doesn,t anyone just put their ignition switch back together instead of buying a whole new/secondhand column.My BA11 switch failed - started by intermitant no start and wipers and a/c not working.Then the ass fell out of the ignition switch. I just put switch back together and redid the factory 4 crimps around the end of the plastic bit where the wires connect.Put some epoxy over it for good measure though. Link to comment https://www.fordxr6turbo.com/forum/topic/83669-bf-ignition-barrel-problem-need-help/page/4/#findComment-1392446 Share on other sites More sharing options...
Qvas New Member 2 Member For: 7y 4m 27d Posted 02/12/17 11:20 AM Share Posted 02/12/17 11:20 AM (edited) Hi everyone, So Ive done as much reading as possible on this problem however Im stuck. My key would not spring back into the acc position after starting and I had to manualy do it myself. I decided to attempt to fix it myself however after removing the ignition switch and the key barrel, the part that sits behind it or mates with the barrel is stuck in a postion where it will not rotate and so I cannot align my key barrel during re assemble. Can anyone tell me how to remove this or fix this? Ps reference link for the picture. Edited 02/12/17 11:22 AM by Qvas Added info Link to comment https://www.fordxr6turbo.com/forum/topic/83669-bf-ignition-barrel-problem-need-help/page/4/#findComment-1647883 Share on other sites More sharing options...
Johns do nothing New Member 2 Member For: 7y 4m 22d Posted 07/12/17 09:33 AM Share Posted 07/12/17 09:33 AM U can u buy a kit now u no longer have to remove the column Bloke in Dandenong auto elec advises on his add will come out to u 360 I think takes an hour he pulls the barrel out anhas a special tool and replaces it somehow much cheaper than full Colombo fit Link to comment https://www.fordxr6turbo.com/forum/topic/83669-bf-ignition-barrel-problem-need-help/page/4/#findComment-1648224 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,447 Member For: 17y 19d Gender: Male Location: Melbourne Posted 07/12/17 09:44 AM Share Posted 07/12/17 09:44 AM if he comes to you, it doesn't sound like a kit... anyway... did you use this service? or just talking about it? and Link to comment https://www.fordxr6turbo.com/forum/topic/83669-bf-ignition-barrel-problem-need-help/page/4/#findComment-1648228 Share on other sites More sharing options...
Qvas New Member 2 Member For: 7y 4m 27d Posted 07/12/17 11:21 AM Share Posted 07/12/17 11:21 AM So initially I thought it was my key barrel however learned that it was my ignition switch like most peoples but by the time I figured it out I had already removed my key barrel causing a saftey mechanisim within the column to engage and therefor you cannot reinstall the key barrel without resetting it. Lock smith came out today and drilled a hole underneath it to reset it. All fixed now. Link to comment https://www.fordxr6turbo.com/forum/topic/83669-bf-ignition-barrel-problem-need-help/page/4/#findComment-1648247 Share on other sites More sharing options...
