  • Bronze Donating Members
  • Member For: 13y 9m 2d
Yep should be fine as long as you can get a column that comes with its key as you need the key to turn the ignition to position 1 to get the barrel out
  • Replies 39
Posted Images
  • Member For: 12y 9m 6d
my BA key seems lose in the ignition, like you go to turn it and it turns freely then finally clicks...been like this for a couple years........im guessing not normal...should I check and make sure the back plate is secure?
cheers
  • Member For: 18y 11m 2d
Some workshop style scan tools can do this programming
  On 20/01/2013 at 9:42 AM, bionicxr6t05 said:
and the new keys need to be programmed by ford.
yep, there's a few options these days, my local locksmith who is set up very well with all the latest equipment did not even know there was a problem with the late model fords
depending on which issues the car has, there is a fix for the return spring issue, but I'm not prepared to do that on a paying customers car as if it fails they will expect a warranty ( and so they should) if they have paid for a job, I'd prefer to do things 100% correct
Weve never had one come back, but if one did our bloke would surely fix it if it was his fault, we give customers both options, $400 or $1500 you can guess which one they choose
  • Member For: 16y 23d
So I have started pulling apart the car to try and fix this issue. So far I have the steering wheel off, the plastic cover off the column and all the wires unplugged.
I have hit a snag now as I don't know how to get the steering shaft off the part that I am trying to remove. I have take some photos of where I am up to with it.
post-34842-0-45465900-1359003593_thumb.j
post-34842-0-95600200-1359003666_thumb.j
