  • Member For: 17y 4m 27d
hi there
I know this topic has been done before but my fgxr6t has 150k on it now and I want to replace the intercooler/piping with something slightly better than stock. does any one know these or have used this product?
http://www.pcpa.com.au/store/fg-xr6-turbo-g6e-fpv-typhoon-intercooler-kit-460x430x55-2-5-alloy-piping.html
I appreciate any help
Rgds mike
  • Member For: 21y 8m 11d
You will most likely need the car tuned if going for any IC upgrade. That IC looks a bit nasty but I have no doubt it will work a lot better than the standard one due to its surface area.
I'd get yourself a budget and then go from there but for only about $3k you could see the little turbo peaking its tits off...
  • I <3 Floods
  • Member For: 13y 9m 13d
It looks like a monza cooler with a pipe kit..
  • Member For: 12y 3m 28d
I've found the hdi cooler kits to be pretty good and they're only about $500-$600 bucks. They flow well and support about 300-320 rwkw. Both me and a mate have bought them and had no problems with them
  • Here since the start...
  • Member For: 22y 18d
You need it to cool well too. Flow is only a part of it.
This is why the Monza coolers do give an improvement that can't be sustained run after run. They flow well, but can't cool for sh*t!
  • Bob the Freaking Builder
  • Member For: 15y 8m 1d
  • Gender: Female
if u dont wanna replace it for power gains then dont bother... no need....
if u wanna replace it for power gains then you WILL need a tune (regardless of the power gain even if there was none as you will over boost and go boom boom) and in which case you are better off speding a few more $$ and getting something bigger and better.
Edited by Princess Fluffy
  • Member For: 17y 5m 20d
Not much to add to the above except
"Lower End Intercooler Kit Advice" - don't
Edited by -SteveR-
Thx for the replies guys
Yeah I've done a k&n, xr8 intake, 100cell cat already and I'm dropping the car in for a tune next week, xcal custom dyno etc.
Don't want massive gains bout 280rwkw should be ok.
It's just that the inter piping is knackered and I don't like those expensive I/cooler kits because they rob front end ground clearance( and I need every mm I can get on my local dirt roads).
Maybe a std f6 might give me what I need, can't seem to find one though
Cheers
Mike
