Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 9d Gender: Male Location: Perth Posted 11/11/14 01:44 AM Share Posted 11/11/14 01:44 AM Sounds like very similar symptoms to the issues I was having with blinked plates Link to comment https://www.fordxr6turbo.com/forum/topic/83653-clutch-recommendations/page/45/#findComment-1511603 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 6m 5d Gender: Male Location: Perth Posted 11/11/14 02:03 AM Share Posted 11/11/14 02:03 AM (edited) That's because the clutch is dragging. Sounds like , bad bleed, not large enough spacer on CSC or bent clutch plate or plates Edited 11/11/14 02:04 AM by arronm Link to comment https://www.fordxr6turbo.com/forum/topic/83653-clutch-recommendations/page/45/#findComment-1511605 Share on other sites More sharing options...
rollex Member 683 Member For: 10y 10m 24d Gender: Male Location: Australia Posted 11/11/14 02:12 AM Share Posted 11/11/14 02:12 AM Take up point is 1cm off the ground and he has given up and said come pick the car up. What do I do? Link to comment https://www.fordxr6turbo.com/forum/topic/83653-clutch-recommendations/page/45/#findComment-1511608 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 6m 5d Gender: Male Location: Perth Posted 11/11/14 02:14 AM Share Posted 11/11/14 02:14 AM WHAT. Did you supply the clutch Link to comment https://www.fordxr6turbo.com/forum/topic/83653-clutch-recommendations/page/45/#findComment-1511609 Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 5m 12d Gender: Male Location: Brisbane Posted 11/11/14 02:16 AM Share Posted 11/11/14 02:16 AM Tell him to fkn fix it lol? As mentioned he HAS to get it right. I wouldn't pick it up just yet, giving up is not good enough. Link to comment https://www.fordxr6turbo.com/forum/topic/83653-clutch-recommendations/page/45/#findComment-1511610 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,460 Member For: 17y 22d Gender: Male Location: Melbourne Posted 11/11/14 02:18 AM Share Posted 11/11/14 02:18 AM If the take up point is 1cm off the firewall, then the CSC is spaced out too far, I believe (or like arronm is hinting at - the clutch diaphragm is too close to top of the CSC). Link to comment https://www.fordxr6turbo.com/forum/topic/83653-clutch-recommendations/page/45/#findComment-1511611 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 6m 5d Gender: Male Location: Perth Posted 11/11/14 02:29 AM Share Posted 11/11/14 02:29 AM If you don't get the box onto the dowels and the shaft into the spigot properly and have trouble lining up the clutch, the clutch plate can be bent by letting the box hang. Either way he just can't give up. Something is wrong, he is a mechanic so FIX itIf he supplied the clutch , get him to put it all back to stock and take is somewhere else. How far do you live from Mal Woods shop , cause I guarantee he won't fukc it up Link to comment https://www.fordxr6turbo.com/forum/topic/83653-clutch-recommendations/page/45/#findComment-1511612 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 1d Gender: Male Location: Adelaide Posted 11/11/14 02:57 AM Share Posted 11/11/14 02:57 AM (edited) And there shines why people have moved on Some seen it in the tunes some are seeing it in the work side of things very sad I apologise for reffering you there rollex but up until now he had been bang on with the mechanical side and knew not only is he cheap but used to be reliable If we were still going we would of pissed this in as we have before,,,, maybe its time to come out of retirement ! Edited 11/11/14 03:01 AM by Butt Plug Link to comment https://www.fordxr6turbo.com/forum/topic/83653-clutch-recommendations/page/45/#findComment-1511614 Share on other sites More sharing options...
rollex Member 683 Member For: 10y 10m 24d Gender: Male Location: Australia Posted 11/11/14 03:04 AM Share Posted 11/11/14 03:04 AM If the plates are bent am I going to know about it? Link to comment https://www.fordxr6turbo.com/forum/topic/83653-clutch-recommendations/page/45/#findComment-1511615 Share on other sites More sharing options...
rollex Member 683 Member For: 10y 10m 24d Gender: Male Location: Australia Posted 11/11/14 03:09 AM Share Posted 11/11/14 03:09 AM He took the box out 3 times if he hasn't got it right by now he isn't ever going to get it right. Npc said the pickup point will improve by at least 1 inch once it is worn in. Does this make sense? Link to comment https://www.fordxr6turbo.com/forum/topic/83653-clutch-recommendations/page/45/#findComment-1511616 Share on other sites More sharing options...
