Clutch Recommendations
Pazzo
  • Member For: 18y 7m 2d
I understand u supply a new spiggot bearing and that's great but with an engine that has common rear main issues iam supprised that u dont see this on a larger scale
But u cant take the blame for a engines issues !!
You are exactly right about we can not be at fault if the engine leaks oil onto the clutch.
This is the only downside to forums at times, if people who don't quite know what they are looking at, go off half cocked about a product failing. By no means is this directed to Trent!
Any good mechanic would clean the area down first.
A rear main leaks from the opposite side of the flywheel and the only them I've ever seen clutches get oil on them from that is if there's no way for the oil to escape the bell housing.
Yes, the rear main is behind the flywheel, but when the flywheel is spinning at 2000rpm on the highway for example, surely this would generate turbulence in the bellhousing and cause the oil to be misty and there is no way of stopping it from going onto the clutch.
The clutch package is on it's way back up now.
Mal has added a few bits and pieces to handle the power & torque and a bit more.
Although has recommended a 2000km bed in for it. Looks like I'll have to behave for a while
The clutch should arrive on Monday with a bit of luck! Definitely let the clutch bed in, and you should be right then! :D We would be keen to see how it goes!
  • The Toxic Rocket
  • Member For: 14y 9m 1d
Got the ute back today with everything fitted up.
Gotta say, I'm going to need to do more leg work at the gym!!
Feel's fantastic but so god damn springy haha, will take a lot to get used too.
Big thanks to Mal wood Automotive for the ginning around and looking after me!
It was a pleasure helping! Glad that it is all back in and running again. You will get used to the pedal feel in no time. :drinks:
My clutch will be pulled out Monday and sent up to Paul Dee how we go Sent from my HTC One XL using Tapatalk 2
Just let me know when, where and some dimensions of the carton and I'll arrange the pick up. :)
  • You've changed man....
  • Member For: 14y 30d
Well, if it's stuffed, why would you want it back? It'd only be good for a bin job anyway.
If it's stuffed from incorrect fitment then you may be able to talk to the installer about it and get some compensation.
Thought I answered this fairly.... must not have posted or got deleted...
Anyway, checkin out a torque clamp in the morning :)
  • Member For: 15y 8d
I've got a question about the spigot bearing. So you supply a new one with the kits, is it a sealed type bearing? (Since the factory one can leak badness where you dont want it).
