  • You've changed man....
  • Member For: 14y 5m 26d
  On 27/01/2013 at 6:51 AM, Rollin said:
If the clutch is cactus and Mal Wood are picking it up for free, why not let them? It's either that or chuck it in the bin....
Then what? they tell me its broken because of semis?
then send id back to me at my expense?
  • Member For: 13y 1m 20d
  On 28/01/2013 at 3:06 AM, boosted_XR said:
Ive got an option 5 in mine and has been good up till now touch wood lol. I use et streets 50% of the time and clutch has been given a good work out, never taken it to the track so dont know hows its like lunching but roll on pulls have been good. that's with 450rwkw
Do you launch with semis ? .
  • ...JD TUNING ADELAIDE...
  • Member For: 17y 22d
Here's a crazy idea
How bout mal wood have two ratings one for street one for motorsport/strip ?
Problem solved
Real world ratings for real applications !!!!
  • Like 2
  On 28/01/2013 at 7:21 AM, boosted_XR said:
Havent lunched with semi's on
That's what seems to kill mine .. But yours is fine with Ets on when on the road. .. Hopefully that info helps
  • The Toxic Rocket
  • Member For: 15y 1m 28d
I just had more problems with mine. Been garaged the past 10 days, took it for a drive down the road. Pedal feel felt good for the first 1km, after that it went out the window.
I can hear a real loud squeak when I depress/release the clutch pedal, noise is coming from outside the car. The pedal also feels like it gets stuck, it's not a consistent feel,
it's sh!t
  • The Toxic Rocket
Got the phone call, the clutch is buggered. It's getting sent down to Malwoods for them to have a look at
  • I <3 Floods
  • Member For: 13y 10m 21d
Interested to hear the feedback from mal on this..
  • Member For: 16y 3m 13d
Well, if it's stuffed, why would you want it back? It'd only be good for a bin job anyway.
If it's stuffed from incorrect fitment then you may be able to talk to the installer about it and get some compensation.
  On 28/01/2013 at 1:09 AM, Michael (HYPOEB) said:
Rollin the point is that you only have 315rwkw. Why have you even got the opt5? Going by the ratings an opt3+ should be fine for your car.
The main discussion of this thread is why are the clutch dying below there ratings,Of course your clutch is going to hold up,Its rated for over 550rwkw.
Dosnt seem like we will get an answer to why as it seems everytime a clutch has been slipping no one is sending them back to Mal Wood to be diagnosed.
Nice videos by the way!
Would have thought the videos would be a pretty good example of why I have/need an option 5....
Don't know why nobody sends the clutches back, seems like they're trying to hide something to me...but I'm naturally a suspicious type of preson though.
Something as inconsequential as finger print oil on the flywheel can have a marked effect on the power handling capabilities of a clutch - a lot of people (even mechanics, ffs, used to do my head in) reckon that oils etc will 'burn off' in service, but it doesn't. It burns INTO the flywheel and glazes it, which wrecks any power handling capability the clutch would otherwise have.
The flywheel, pressure plate and friction disc/s must be surgically clean before assembly - only perfectly clean hands, fresh super clean rags, copious amounts of 'brake clean' (which evaporates without leaving any residue) and compressed air must be used.
I don't expect any of you gents with shiny new cars would have to worry about oil leaks just yet, but rear main seal, sump, rocker cover or input shaft oil leaks can also affect the clutch - even if it's not dripping directly onto it, it gets pretty windy inside a bell housing at 6000rpm, and oil vapours can contaminate the clutch as well.
I'm dead keen to see pics of dead clutches here - anyone got pics?
