SMURF6 Jamie Donating Members 380 Member For: 16y 1m 16d Gender: Male Location: Maroubra, Sydney, NSW Posted 16/01/13 01:10 AM Share Posted 16/01/13 01:10 AM I need some help rolling my rear guards on the FG ute. I have heard a million different stories on how to do it so I decided to create this topic and try get a step by step guide put together from everyone who has done it. Link to comment Share on other sites More sharing options...
STAINLESS again plz You've changed man.... Donating Members 8,142 Member For: 14y 2m 21d Gender: Male Location: 2 Fuchsia Court, Narre Warren. 3805 Posted 16/01/13 01:29 AM Share Posted 16/01/13 01:29 AM (edited) Dont drill the spotwelds. Get 1mm grinder blade in between the bracket and guard lip where they are spotwelded and cut through the weld. Repeat. Do not drill the spot welds.The lip is approx 20mm, this gives the roller 20mm of leaverage. Once drilled you are left with maybe 5mm. This is fail because the roller will roll the 20mm areas and where its 5mm it wont move. This will leave 2 very noticable dints on the outside right where the spotwelds were. Edited 16/01/13 01:33 AM by STAINLESS 2 Link to comment Share on other sites More sharing options...
STAINLESS again plz You've changed man.... Donating Members 8,142 Member For: 14y 2m 21d Gender: Male Location: 2 Fuchsia Court, Narre Warren. 3805 Posted 16/01/13 01:38 AM Share Posted 16/01/13 01:38 AM (edited) Dont do this!<br /><br /><br /><br /><span rel='lightbox'><img src='<a href='http://i1096.photobucket.com/albums/g323/B3NJ1_1978/Ally%20Tray%20Build/D91D0557-5CA6-471A-A3E0-89F8C6E6A2FE-77855-0000148AC4836FC4_zps386e196a.jpg'>http://i1096.photobucket.com/albums/g323/B3NJ1_1978/Ally%20Tray%20Build/D91D0557-5CA6-471A-A3E0-89F8C6E6A2FE-77855-0000148AC4836FC4_zps386e196a.jpg</a>' alt='Posted Image' class='bbc_img' /></span><br /><br />Also, make sure you do it BEFORE shortening diff.*edit. Fix the site for mobile fukkins. Edited 16/01/13 01:43 AM by STAINLESS Link to comment Share on other sites More sharing options...
SMURF6 Jamie Donating Members 380 Member For: 16y 1m 16d Gender: Male Location: Maroubra, Sydney, NSW Posted 16/01/13 02:39 AM Author Share Posted 16/01/13 02:39 AM So just angle grind the welds and then remove the piece ? Link to comment Share on other sites More sharing options...
lrmcdowell Donating Members 730 Member For: 13y 6m 22d Gender: Male Location: Randwick, sydney Posted 16/01/13 04:28 AM Share Posted 16/01/13 04:28 AM jamie have you got new wheels on your ute now? god rid of the pink oneS? Link to comment Share on other sites More sharing options...
mummba Member 525 Member For: 15y 15d Gender: Male Location: perth Posted 16/01/13 05:00 AM Share Posted 16/01/13 05:00 AM yep as stainless says grind away the spot welds, I slowly bent my brackets back and forth till they cracked at the weld then just ground the weld off... once done its a piece of piss to roll em Link to comment Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 17y Gender: Male Location: Vic Posted 16/01/13 05:25 AM Share Posted 16/01/13 05:25 AM I drilled the welds. Link to comment Share on other sites More sharing options...
Panda Eyes flame magnet Gold Donating Members 5,674 Member For: 16y 10m 4d Gender: Male Location: adelaide hills- 'race air' central Posted 16/01/13 05:58 AM Share Posted 16/01/13 05:58 AM I like the pink ones! Link to comment Share on other sites More sharing options...
wilba Member 828 Member For: 16y 4m 18d Gender: Male Posted 25/01/13 05:13 AM Share Posted 25/01/13 05:13 AM I'm keen on this thread . As I took the ute in to get gaurds rolled but the roller didnt have a enuff force to roll the lip because of the fail offset of the hub Link to comment Share on other sites More sharing options...
Krazy Kyle Get It To Wheelspin Uncontrolably Then Give It Another 5 Pounds Cruise Control 2,697 Member For: 14y 4m 27d Gender: Male Location: Work Posted 08/03/13 12:59 PM Share Posted 08/03/13 12:59 PM yeah Ben can u explain your pic... I dunno what im looking at.and when u say roll, u mean that 20mm lip that faces into the tyre right? Link to comment Share on other sites More sharing options...
