sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 8m 4d Gender: Male Location: Far north queensland Posted 20/01/14 11:09 AM Share Posted 20/01/14 11:09 AM (edited) On 20/01/2014 at 9:42 AM, Ralph Wiggum said: *cockstestcocks cocksedit J@ ya tosser it's not even censored farken Edited 20/01/14 11:10 AM by sexual harrassment panda 1 Link to comment https://www.fordxr6turbo.com/forum/topic/83577-fuel-pressure-regulator-aftermarket-for-oem-rail/page/5/#findComment-1451123 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 30d Gender: Male Location: Adelaide Posted 20/01/14 10:03 PM Share Posted 20/01/14 10:03 PM Dammit Cock Link to comment https://www.fordxr6turbo.com/forum/topic/83577-fuel-pressure-regulator-aftermarket-for-oem-rail/page/5/#findComment-1451178 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 7d Gender: Male Location: Perth Posted 21/01/14 01:39 AM Share Posted 21/01/14 01:39 AM whataco(k Link to comment https://www.fordxr6turbo.com/forum/topic/83577-fuel-pressure-regulator-aftermarket-for-oem-rail/page/5/#findComment-1451209 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 30d Gender: Male Location: Adelaide Posted 21/01/14 02:11 AM Share Posted 21/01/14 02:11 AM So any thought on my spelling infested post oh wise gods ? Link to comment https://www.fordxr6turbo.com/forum/topic/83577-fuel-pressure-regulator-aftermarket-for-oem-rail/page/5/#findComment-1451215 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 7d Gender: Male Location: Perth Posted 21/01/14 02:20 AM Share Posted 21/01/14 02:20 AM I haven't actually read it Link to comment https://www.fordxr6turbo.com/forum/topic/83577-fuel-pressure-regulator-aftermarket-for-oem-rail/page/5/#findComment-1451219 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 2m 30d Gender: Male Posted 21/01/14 06:37 AM Share Posted 21/01/14 06:37 AM http://www.evoxforums.com/forums/showthread.php?t=2803644 pages, I think your answer might be in there somewhere, tell me when you find it cause I'd like to know more.That read will keep your minds off cocks. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/83577-fuel-pressure-regulator-aftermarket-for-oem-rail/page/5/#findComment-1451281 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 2m 30d Gender: Male Posted 22/01/14 01:27 AM Share Posted 22/01/14 01:27 AM So let me get this straight. The FG has this venturi valve cause it has the split fuel tank under the seat and it needs this valve to pull fuel over the driveshaft hump into the primary tank with the pump in it.I take it the BA/BF has no venturi valve cause just a single tank.So if you put in say a Walbro 400lph intank pump in a FG, then the valve relief is a bit small and you could drill it out and it would still pull out fuel out of the otherside of the tank provided you don't overdrill it and get the correct pressure out of the FPReg. Link to comment https://www.fordxr6turbo.com/forum/topic/83577-fuel-pressure-regulator-aftermarket-for-oem-rail/page/5/#findComment-1451407 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 11m 22d Gender: Male Location: OZ Posted 22/01/14 01:34 AM Author Share Posted 22/01/14 01:34 AM Most swirl tanks will use a venturi to keep the pot full whilst the surrounding tank is low....to prevent surge. Link to comment https://www.fordxr6turbo.com/forum/topic/83577-fuel-pressure-regulator-aftermarket-for-oem-rail/page/5/#findComment-1451409 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 30d Gender: Male Location: Adelaide Posted 22/01/14 01:40 AM Share Posted 22/01/14 01:40 AM Trana the fg tank is same/same to b series Correct toads hence why I think its important to not use this place to have less restriction The effect imho would be destroyed or less efficient if the hole ( first one ) was just drilled out I feel a pressure realease needs to come into effect either before or after but not to disrupt the first vital venturi effect !! Link to comment https://www.fordxr6turbo.com/forum/topic/83577-fuel-pressure-regulator-aftermarket-for-oem-rail/page/5/#findComment-1451412 Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 12y 2m 27d Gender: Male Location: Liverpool Posted 22/01/14 06:08 AM Share Posted 22/01/14 06:08 AM Has anyone had the chance to look at what kpm have come up with to address the issue? I know they supply a fuel reg but surely they have done something with the swirl pot? Link to comment https://www.fordxr6turbo.com/forum/topic/83577-fuel-pressure-regulator-aftermarket-for-oem-rail/page/5/#findComment-1451453 Share on other sites More sharing options...
