Peppy_t92 Silver Donating Members 748 Member For: 12y 2m 27d Gender: Male Location: Liverpool Posted 18/01/14 05:07 AM Share Posted 18/01/14 05:07 AM Hey guys, sorry for reviving an old thread I'm in the process of setting my car up so I can tune it using vcm. It currently has a generic sct tune in it making around 360-370rwkw (going off 1/4mile time), I installed the walbro 400lt e85 compatible pump in my standard swirl pot, the car runs fine the way it is but I had a hunch that it wasn't running at 4bar anymore so I will need the adjustability before I started playing with the tune. Anyway, I bought the 034 adjustable reg and I got a fuel pressure gauge also. I put the gauge on first to see what the fp is currently, it was at 86psi and dropped slightly when I opened the throttle, this is obviously not good, I havnt logged any fuel trims as yet.. Anyway I put the new adjustable reg in and I could only get it down to about 65psi, so I'm assuming their is a restriction somewhere, possibly part of the swirl pot? Have you come across this? What can be done? Thanks Joe Link to comment https://www.fordxr6turbo.com/forum/topic/83577-fuel-pressure-regulator-aftermarket-for-oem-rail/page/3/#findComment-1450824 Share on other sites More sharing options...
ScatterBrain Donating Members 316 Member For: 16y 28d Gender: Male Location: Brisbane Posted 18/01/14 05:50 AM Share Posted 18/01/14 05:50 AM In the return line in the top of the swirl pot there's a ball valve that needs to be removed. Also the back return jet thing on the bottom of the pot need to be modified by in creasing the outlet hole size. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/83577-fuel-pressure-regulator-aftermarket-for-oem-rail/page/3/#findComment-1450832 Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 12y 2m 27d Gender: Male Location: Liverpool Posted 18/01/14 06:08 AM Share Posted 18/01/14 06:08 AM On 18/01/2014 at 5:50 AM, ScatterBrain said: In the return line in the top of the swirl pot there's a ball valve that needs to be removed. Also the back return jet thing on the bottom of the pot need to be modified by in creasing the outlet hole size. Thanks for that ScatterBrain, I'll let you know how I go Link to comment https://www.fordxr6turbo.com/forum/topic/83577-fuel-pressure-regulator-aftermarket-for-oem-rail/page/3/#findComment-1450833 Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 11y 11m 28d Gender: Male Posted 18/01/14 10:43 PM Share Posted 18/01/14 10:43 PM Forgive my ignorance, but some of the upgraded rails I've seen for sale are a fix to a potential restriction with a stock rail? Link to comment https://www.fordxr6turbo.com/forum/topic/83577-fuel-pressure-regulator-aftermarket-for-oem-rail/page/3/#findComment-1450921 Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 8m 4d Gender: Male Location: Far north queensland Posted 18/01/14 11:36 PM Share Posted 18/01/14 11:36 PM (edited) FiftyOne - Fuel Pressure Reg is a seperate piece, it's the biggest restriction. On 18/01/2014 at 5:07 AM, Peppy_t92 said: Hey guys, sorry for reviving an old threadI'm in the process of setting my car up so I can tune it using vcm. It currently has a generic sct tune in it making around 360-370rwkw (going off 1/4mile time), I installed the walbro 400lt e85 compatible pump in my standard swirl pot, the car runs fine the way it is but I had a hunch that it wasn't running at 4bar anymore so I will need the adjustability before I started playing with the tune.Anyway, I bought the 034 adjustable reg and I got a fuel pressure gauge also. I put the gauge on first to see what the fp is currently, it was at 86psi and dropped slightly when I opened the throttle, this is obviously not good, I havnt logged any fuel trims as yet.. Anyway I put the new adjustable reg in and I could only get it down to about 65psi, so I'm assuming their is a restriction somewhere, possibly part of the swirl pot?Have you come across this? What can be done?Thanks JoeSooooooooooooooooooo who's doing your engine rebuild? Edited 18/01/14 11:36 PM by sexual harrassment panda 1 Link to comment https://www.fordxr6turbo.com/forum/topic/83577-fuel-pressure-regulator-aftermarket-for-oem-rail/page/3/#findComment-1450928 Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 12y 2m 27d Gender: Male Location: Liverpool Posted 19/01/14 04:01 AM Share Posted 19/01/14 04:01 AM On 18/01/2014 at 11:36 PM, sexual harrassment panda said: FiftyOne - Fuel Pressure Reg is a seperate piece, it's the biggest restriction. Sooooooooooooooooooo who's doing your engine rebuild? That would be me Link to comment https://www.fordxr6turbo.com/forum/topic/83577-fuel-pressure-regulator-aftermarket-for-oem-rail/page/3/#findComment-1450948 Share on other sites More sharing options...
dragons90 Member 42 Member For: 17y 28d Gender: Male Posted 19/01/14 06:49 AM Share Posted 19/01/14 06:49 AM 370rwkw with a generic tune. Link to comment https://www.fordxr6turbo.com/forum/topic/83577-fuel-pressure-regulator-aftermarket-for-oem-rail/page/3/#findComment-1450957 Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 12y 2m 27d Gender: Male Location: Liverpool Posted 19/01/14 06:54 AM Share Posted 19/01/14 06:54 AM 11.81@124 you can do the maths. By the way I can't fault the tune, I understand it not perfect and I know the reasons that it's not ideal, but it has never skipped a beat, so I'm not interested in hearing any trolling about it, I've heard it all before. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/83577-fuel-pressure-regulator-aftermarket-for-oem-rail/page/3/#findComment-1450959 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 2m 30d Gender: Male Posted 19/01/14 12:25 PM Share Posted 19/01/14 12:25 PM Howabout posting the tune you pull on the VCM tune repository. Link to comment https://www.fordxr6turbo.com/forum/topic/83577-fuel-pressure-regulator-aftermarket-for-oem-rail/page/3/#findComment-1450989 Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 12y 2m 27d Gender: Male Location: Liverpool Posted 19/01/14 06:24 PM Share Posted 19/01/14 06:24 PM For sure trana, as soon as I purchase the mpvi Link to comment https://www.fordxr6turbo.com/forum/topic/83577-fuel-pressure-regulator-aftermarket-for-oem-rail/page/3/#findComment-1450999 Share on other sites More sharing options...
