ChrisJager123 Member 43 Member For: 16y 3m 28d Posted 14/01/13 03:55 AM Share Posted 14/01/13 03:55 AM Hi guys just wanting to know about your ideas on modding the stock swirl pot? say with a intank 400lph pump do you guys mod the bottom of the pot to help with flow? Or leave it stock as putting holes in the pot stops it filling up when fuel is low in the tank? a good mate of mine is new to pump change and wanted me to find out im not 100% sure what I would do??thanks guys Link to comment https://www.fordxr6turbo.com/forum/topic/83567-walbro-400lph-in-stock-swirl-pot/ Share on other sites More sharing options...
xr6t_ute Donating Members 2,281 Member For: 17y 11m 4d Gender: Male Location: south east suburbs Posted 14/01/13 06:08 AM Share Posted 14/01/13 06:08 AM Leave it as is, just change the intank pump, and its fine, maybe run a surgetank if you really start pushing power. Link to comment https://www.fordxr6turbo.com/forum/topic/83567-walbro-400lph-in-stock-swirl-pot/#findComment-1349130 Share on other sites More sharing options...
Benny Member 1,869 Member For: 21y 9m 23d Gender: Male Location: Newcastle Posted 14/01/13 09:56 AM Share Posted 14/01/13 09:56 AM I've installed a Walbro 400 in my standard swirl pot with no issues so far. Benny. Link to comment https://www.fordxr6turbo.com/forum/topic/83567-walbro-400lph-in-stock-swirl-pot/#findComment-1349290 Share on other sites More sharing options...
ratter Member 6,793 Member For: 19y 2d Gender: Male Location: @ my laptop Posted 14/01/13 10:03 AM Share Posted 14/01/13 10:03 AM did you check fuel pressure before and after or record your fuel rims before and after? 1 Link to comment https://www.fordxr6turbo.com/forum/topic/83567-walbro-400lph-in-stock-swirl-pot/#findComment-1349296 Share on other sites More sharing options...
Benny Member 1,869 Member For: 21y 9m 23d Gender: Male Location: Newcastle Posted 14/01/13 10:14 AM Share Posted 14/01/13 10:14 AM Yeah Ratter I did. The fuel pressure has increased from 52 > 62psi at idle. The car is trimming fuel (can't recall % at this moment) but this will be adjusted for when tuning in the next few weeks. The restriction in the factory reg and return line is causing the increased pressure. Benny. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/83567-walbro-400lph-in-stock-swirl-pot/#findComment-1349301 Share on other sites More sharing options...
ratter Member 6,793 Member For: 19y 2d Gender: Male Location: @ my laptop Posted 14/01/13 10:37 AM Share Posted 14/01/13 10:37 AM pretty much what we see Link to comment https://www.fordxr6turbo.com/forum/topic/83567-walbro-400lph-in-stock-swirl-pot/#findComment-1349322 Share on other sites More sharing options...
ChrisJager123 Member 43 Member For: 16y 3m 28d Posted 14/01/13 02:02 PM Author Share Posted 14/01/13 02:02 PM Thanks guys so by adding a aftermarket reg and running stock fuel pressure will the car stop trying to take fuel out?? Car seems better and tends not to lean out as much but have yet to dyno.. Link to comment https://www.fordxr6turbo.com/forum/topic/83567-walbro-400lph-in-stock-swirl-pot/#findComment-1349451 Share on other sites More sharing options...
ChrisJager123 Member 43 Member For: 16y 3m 28d Posted 14/01/13 02:11 PM Author Share Posted 14/01/13 02:11 PM Also I heard of a High flow bosch regulator that swaps stock reg?? KPM motorsport sell them in there streetfighter kits. Anyone know how to get one as im not sure if kpm sell alone?? Link to comment https://www.fordxr6turbo.com/forum/topic/83567-walbro-400lph-in-stock-swirl-pot/#findComment-1349453 Share on other sites More sharing options...
Benny Member 1,869 Member For: 21y 9m 23d Gender: Male Location: Newcastle Posted 15/01/13 09:46 AM Share Posted 15/01/13 09:46 AM I'm unsure of the part number for the genuine bosch unit. If anyone has this info I'd certainly like to know. Alternatively you can use this reg http://www.034motors...ar-p-19082.html. Thanks to IH8TOADS for this link. In addition to the reg being a restriction on the return the factory swirl pot has a restriction also. Both of these should be considered. Benny. Link to comment https://www.fordxr6turbo.com/forum/topic/83567-walbro-400lph-in-stock-swirl-pot/#findComment-1349819 Share on other sites More sharing options...
Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 15y 18d Gender: Male Location: Gold Coast Posted 01/03/13 09:13 AM Share Posted 01/03/13 09:13 AM For my E85 tune, on little turbo, I'm trying to sort my fuel pump needs. I'll be running 1000cc injectors. Thought I'd found the answer with the Walbro TIA485-2 400LPH E85. You can buy these in a drop in assembly but.... contacted old mate (as per link) and he said the loom, reg etc isn't up to it.So, will the GSS340 with 255LPH get it done? I would do a surge and 044 (or similar) later if I upgrade the turbo. So for now, just trying to get an intank that will cut it without altering the loom etc. Boost will still be around the 13 - 14psi mark on E85. Hoping to sqeeze around 340rwkw out of the little huffer on the corn juice.Advice from anybody that has gone down this path would be great http://www.ebay.com.au/itm/290601707527?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649 1 Link to comment https://www.fordxr6turbo.com/forum/topic/83567-walbro-400lph-in-stock-swirl-pot/#findComment-1367859 Share on other sites More sharing options...
