joshmcmillan Member 46 Member For: 13y 4m 15d Gender: Male Location: Mid North Coast, NSW Posted 11/01/13 12:43 PM Share Posted 11/01/13 12:43 PM I posted this on another forum and I thought I'd post it here as well to get the best range of answers.So, my XR6 Turbo has a 3" Xforce catback along with high flow cat and dump. It's a mild steel system and has been on the car for about 6 years.The middle muffler has recently developed a few holes, you can hear it from the side of the car, and was also pointed out during its 90k service.Now, the car has had a custom tune at CV Performance in Sydney and on the 98 tune which I run 100% of the time (less aggressive boost), it is doing 11.5 PSI, which goes down to 9 PSI after a few seconds WOT. It also has the F6 secondary intake, K&N Filter, but is otherwise stock.Firstly, if I cut the exhaust out completely and replace with a 3" straight pipe, would I be likely to see over-boost, lean out, or damage the engine in any way?Secondly, does anyone would to have a guess at how loud it would be, the second muffler is pretty massive with two pipes coming out of the muffler.My other option I guess would be to replace it with another XForce muffler, or a hotdog or something. I don't want it insanely loud but wouldn't mind it a little bit louder. Link to comment https://www.fordxr6turbo.com/forum/topic/83535-will-i-get-overboostleanout-cutting-middle-muffler-out-of-x-force-3/ Share on other sites More sharing options...
Cameron02 Member 164 Member For: 12y 5m 5d Posted 11/01/13 01:00 PM Share Posted 11/01/13 01:00 PM As far as middle muffler removal goes. You can do a search as plenty of people have done it. It will probably put your over the legal limit of 90dba so I would hang on to your old system if I was you. I have a completly sock system. With the centre muffler removed my car tested at 89dba and 93dba on deceleration due to gargle/poping sound. Link to comment https://www.fordxr6turbo.com/forum/topic/83535-will-i-get-overboostleanout-cutting-middle-muffler-out-of-x-force-3/#findComment-1348123 Share on other sites More sharing options...
joshmcmillan Member 46 Member For: 13y 4m 15d Gender: Male Location: Mid North Coast, NSW Posted 11/01/13 01:02 PM Author Share Posted 11/01/13 01:02 PM On 11/01/2013 at 1:00 PM, Cameron02 said: As far as middle muffler removal goes. You can do a search as plenty of people have done it. It will probably put your over the legal limit of 90dba so I would hang on to your old system if I was you. I have a completly sock system. With the centre muffler removed my car tested at 89dba and 93dba on deceleration due to gargle/poping sound.I know a heap of people remove the standard middle muffler without a problem, I just thought that as mine is a complete aftermarket exhaust with a tune, that it might be different. I'd be more worried about lean outs than overboost. Link to comment https://www.fordxr6turbo.com/forum/topic/83535-will-i-get-overboostleanout-cutting-middle-muffler-out-of-x-force-3/#findComment-1348124 Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 6m 23d Gender: Male Posted 11/01/13 07:01 PM Share Posted 11/01/13 07:01 PM (edited) I would say you would have to put it on dyno for touch up... If exhaust was stock the cat would be your restriction... You have a full exhaust with a high flow cat.. Your middle muffler will be your restriction now..If you cut it out might flow to well now and have no restriction so I would atleast throw it back on dyno to check things out to be safe. Edited 11/01/13 07:02 PM by Pazzo XR6T Link to comment https://www.fordxr6turbo.com/forum/topic/83535-will-i-get-overboostleanout-cutting-middle-muffler-out-of-x-force-3/#findComment-1348138 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 14d Gender: Male Location: Adelaide Posted 11/01/13 10:08 PM Share Posted 11/01/13 10:08 PM ^^^ this guy ^^^ Link to comment https://www.fordxr6turbo.com/forum/topic/83535-will-i-get-overboostleanout-cutting-middle-muffler-out-of-x-force-3/#findComment-1348171 Share on other sites More sharing options...
xr6t_ute Donating Members 2,281 Member For: 17y 10m 20d Gender: Male Location: south east suburbs Posted 11/01/13 11:23 PM Share Posted 11/01/13 11:23 PM It will definately change your tune since you have the 3" aftermarket exhaust, it will definately boost spike and run leaner,that's why your safest bet is to do what ^^^^^ that guy said and throw it on a dyno for a run. And you will see how much it changed. Link to comment https://www.fordxr6turbo.com/forum/topic/83535-will-i-get-overboostleanout-cutting-middle-muffler-out-of-x-force-3/#findComment-1348199 Share on other sites More sharing options...
joshmcmillan Member 46 Member For: 13y 4m 15d Gender: Male Location: Mid North Coast, NSW Posted 12/01/13 02:59 AM Author Share Posted 12/01/13 02:59 AM Thanks for the replies. Ok so as an alternative, if I was to put say a 3" redback hotdog on it, would that make the situation better?Getting the tune checked out isn't the worry, but as it's been years since it was tuned, I'm still running the old CAPA flash tuner, and don't like the idea of forking out $1500 for an X3 and tune (not yet anyway, I'll do so when I change injectors, intercooler etc...)If that wouldn't make it safe, well I guess it's try find an exact muffler replacement from X-Force. Link to comment https://www.fordxr6turbo.com/forum/topic/83535-will-i-get-overboostleanout-cutting-middle-muffler-out-of-x-force-3/#findComment-1348272 Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 6m 23d Gender: Male Posted 12/01/13 03:25 AM Share Posted 12/01/13 03:25 AM What ever you do get it checked after on dyno Link to comment https://www.fordxr6turbo.com/forum/topic/83535-will-i-get-overboostleanout-cutting-middle-muffler-out-of-x-force-3/#findComment-1348277 Share on other sites More sharing options...
joshmcmillan Member 46 Member For: 13y 4m 15d Gender: Male Location: Mid North Coast, NSW Posted 12/01/13 03:28 AM Author Share Posted 12/01/13 03:28 AM I surely will Pazzo. If it's not safe after an similar muffler replacement well I'd have no option but to get it retuned.For the mean time I might use some muffler putty and see how long I can get it to last Link to comment https://www.fordxr6turbo.com/forum/topic/83535-will-i-get-overboostleanout-cutting-middle-muffler-out-of-x-force-3/#findComment-1348279 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 11m 18d Gender: Male Location: @ my laptop Posted 12/01/13 04:24 AM Share Posted 12/01/13 04:24 AM even if the afr is acceptable it does not mean it is safe!if the boost level is even a little more than when tuned, the spark tables most likely not have been set to any higher than when tuned and damage may occur, and if the afr is even slightly leaner than when tuned, but what others consider safe it still may cause knock issues as leaner AFR's can not tolerate as much spark.End of the day, if the boost remains identical and the afr is identical to when tuned it may be safe, but that still does not allow for wear and tear if the tune was done long time ago Link to comment https://www.fordxr6turbo.com/forum/topic/83535-will-i-get-overboostleanout-cutting-middle-muffler-out-of-x-force-3/#findComment-1348302 Share on other sites More sharing options...
