New Advan Rims For My Fg F6
will_045
  • Member For: 13y 1m 3d
Thought I'd share this so that people can see that 19 x 10 rears can fit under an FG F6 sedan....
I researched a lot before I purchased these rims, as I didn't want to spend a lot of coin and not get rims that fit right....
Specs for the FG F6 sedan standard rims are as follows:
19 x 8" @ +36.5mm offset
245 / 35 / ZR19
Rim only weight: 15.7kg
Rim with tyre @ 38psi weight: 26.75kg
5 / 114.3mm stud pattern
Centre bore: 70.6mm
Hub length: 37mm
I forked out a bit more cash for these rims, as I could really justify spending more to get a quality rim.
I went with Yokohama Advan Racing RS.
Specs:
19 x 9 fronts @ +29mm offset
245 / 35 / ZR19
front rim only weight: 8.6kg
front rim with 245 tyre @ 38psi: 20.6kg
19 x 10 rears @ +35mm offset
275 / 30 / ZR19
rear rim only weight: 9.2kg
rear rim with 275 tyre @38psi: 24.25kg
Sooooo, the rims only saved 27.2kg of unsprung weight over standard....which is massive!! By the time the rubber went on and air went in, the total weight save was 17.3kg of unsprung weight...looks like the extra rubber on the rear was a bit heavy, but still a massive weight save!
Some people may laugh because it's a road car and race rims are unnecessary, but I don't give a sh*t. I can afford it and I definitely think it was worth every cent. In the seat of your pants, the car feels like it accelerates easier, not more powerful, but definitely feels like there's less weight being lugged around. But the biggest difference noticed is in the braking. Definitely pulls up stronger and harder, and also, will take longer to suffer from brake fade on those mountain days as there's less weight for the brakes to be stopping.
Concluding, I can honestly notice a big difference in the braking, and suspension feel with lighter rims, also acceleration, so definitely worth it if you can fork out $4,500!!!!
Now for some pics ;)
post-49495-0-26535700-1357626800_thumb.j
post-49495-0-78204200-1357626810_thumb.j
post-49495-0-91574600-1357626815_thumb.j
post-49495-0-70357400-1357626821_thumb.j
post-49495-0-41192100-1357626832_thumb.j
post-49495-0-42501700-1357626844_thumb.j
post-49495-0-23543800-1357626855_thumb.j
post-49495-0-48180100-1357626866_thumb.j
post-49495-0-96862300-1357626876_thumb.j
post-49495-0-24342100-1357626890_thumb.j
post-49495-0-86066300-1357626908_thumb.j
post-49495-0-20631200-1357626919_thumb.j
post-49495-0-89665200-1357626926_thumb.j
post-49495-0-26658300-1357626937_thumb.j
post-49495-0-49381400-1357626945_thumb.j
post-49495-0-13459600-1357626954_thumb.j
post-49495-0-81260300-1357626958_thumb.j
post-49495-0-38298200-1357626967_thumb.j
post-49495-0-25355500-1357626979_thumb.j
post-49495-0-17597000-1357626991_thumb.j
post-49495-0-36206300-1357627033_thumb.j
post-49495-0-77279700-1357627039_thumb.j
post-49495-0-69482400-1357627048_thumb.j
post-49495-0-11349700-1357627057_thumb.j
post-49495-0-01040100-1357627065_thumb.j
  • Like 10
