Fg Memory Seat Upgrade
tdog
  • Member For: 18y 10m 12d
Well my G6E seat memory doesnt work - I personally wouldn't bother. I would imagine it would be a prett big job, unsure if any of the looms are even there. At a miniumum, you'd need the control box and seat base with all the actuators and sh*t.
  • 4 weeks later...
  • Member For: 12y 6m 29d
The G6 Memory seats also have memory based on the Key you are Using, so if you Insert another Key it will move them to it's memory.
if all it is is just a Memory ECU then it should be Easy if it's just a Plug and play e.g if the factory loom has loose plugs for that provision,
otherwise you'll need a wiring diagram and tap into your factory loom etc.
Otherwise it could be the Body Control Module which controls it and may require swapping? I'm not too familiar with the FG as mine is very new so I have not gone around
experimenting much.
