Help! Car Dash Is Showing Warning Lights?!
Chemarrie
  • Member For: 12y 2m 9d
  • Gender: Female
I own a xr6t ba 2004 manual and today I went for a drive to bondi after 10mins I saw my (ABS, ! , Boost/Skid) lights all came on I pulled over turned car off and on again drove off the lights were gone until mins later this happened a few times today. I am worried something is wrong.
I put new wheels on the back yesterday surely that could have nothing to do with the warning signals?
  • Member For: 19y 27d
Pretty sure if your wheel sizing is too different from front to rear, or from left to right even (rolling diameter is different) the ABS system hates it and will cause you problems. I know it happens on FG's.
Do you have a flash tuner to check codes?
  • Gender: Female
Yeh I have temp 20's on the back and stock 17's on the front as I need to purchase Spacers (Another issue) FML....
Is it dangerous to have different sizes for about a week on?
also it is showing the skid light with it also so u think its from the wheels being different sizes aswell.
Thanks
  • I <3 Floods
  • Silver Donating Members
  • Member For: 13y 7m 12d
The skid light is traction control.. If the wheel speed sensors are indicating different speeds caused by differet sized rims traction control switches itself off I think...
  • Sucker
  • Moderating Team
  • Member For: 20y 10m 15d
Dangerous if you're counting on your ABS or TC working when you need it too. So yeah...I'd certainly recommend it.
  • Member For: 17y 1m 22d
take them off !! when I had mismatched tyres my brakes would not work properly. there was prob a couple cm difference in rolling diameter, yours must be way out its dangerous.
  • Like 2
  • Gender: Female
Ok im not going anywhere today so I will leave them on but tomorrow I will go into wheels places and try buy my spacers and put them on asap if cant get them asap I will take the 20's off. =) Thanks
  • Member For: 16y 7m 9d
Should you consider trading in the 20s and getting some 19s to avoid the use of spacers? These cars can be dangerous at the best of times so mitigating that risk could be your best option.
Plus I think 19s on a BA at the right height look perfect.
