Tailshaft Centre Bearing Failure
Stock_as_a_rock
  • Member For: 12y 1m 8d
So I've had a tailshaft centre bearing failure. I'm wondering if any of the sponsors or other companies have found a solution other than the Hardy spicer tailshafts that I've read about. I live in WA so a perth local workshop would be a preference and if anyone has a rough cost that'd be great.
  • Member For: 14y 3m 29d
Some driveshaft repairers are putting Late model camira ones in. Pretty sure the shaft has to be modified. But once done if it fails again its an easier fix. Had my tailshaft upgraded not long ago, but he left mine factory stock as he hadnt seen many failures..well atleast in FG's
  • Member For: 16y 12d
I had mine done at Monsta torque when my centre bearing failed with an upgraded shaft. Give them a call to find out a price for your model etc.
  • Member For: 13y 20d
Phil at Final Drive engineering, I just had a built Tailshaft put in by him and he did an oversize centre bearing at the same time. Good service and cheapest by $650 compared to hardy spicer. Oh and he used chromoly where as Hardys only offered steel
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 6m 16d
<blockquote class='ipsBlockquote'data-author="josh_hammy" data-cid="1345138" data-time="1357435793"><p>
Phil at Final Drive engineering, I just had a built Tailshaft put in by him and he did an oversize centre bearing at the same time. Good service and cheapest by $650 compared to hardy spicer. Oh and he used chromoly where as Hardys only offered steel</p></blockquote>
Any piks bloke , that's a bargan !!
Front yoke changed to a 1350 series uni
Over size centre bearing
Centre uni upgraded to 1350 series
Rear CV replaced as it was shagged
Front and rear tubing is 2.5" thick wall chromoly.
Built, balanced and fitted for $1600 inc gst
