Panda Eyes flame magnet Gold Donating Members 5,674 Member For: 16y 5m 28d Gender: Male Location: adelaide hills- 'race air' central Posted 04/01/13 09:55 AM Share Posted 04/01/13 09:55 AM need to read pazzo....said tried 19 then put 17's back on.. Link to comment Share on other sites More sharing options...
Panda Eyes flame magnet Gold Donating Members 5,674 Member For: 16y 5m 28d Gender: Male Location: adelaide hills- 'race air' central Posted 04/01/13 09:56 AM Share Posted 04/01/13 09:56 AM yes et will denote offset.look up honda (whatever model) offset on google and you should be able to find the offset they require.only way to fix is hub spacer, but they are illegal (even though plenty run them) but you risk a defect if you do... Link to comment Share on other sites More sharing options...
Chemarrie Member 58 Member For: 11y 10m 13d Gender: Female Location: Blacktown Posted 04/01/13 09:59 AM Author Share Posted 04/01/13 09:59 AM First pic shows a 17" tyre and last one rims look bigger like a 19".your write sorry wrong pic the new 19's wheel says 245/35r20 95y Link to comment Share on other sites More sharing options...
Panda Eyes flame magnet Gold Donating Members 5,674 Member For: 16y 5m 28d Gender: Male Location: adelaide hills- 'race air' central Posted 04/01/13 10:02 AM Share Posted 04/01/13 10:02 AM ha ha ha they are 20's...maybe do some reading up on the wheel threads to increase your understanding of whats what, or search the interwebs for explanations on sizes, load ratings, offsets etc.. 1 Link to comment Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 14y 9m 27d Gender: Male Location: Christchurch, New Zealand Posted 04/01/13 10:02 AM Share Posted 04/01/13 10:02 AM Somewhere on the inside of the rim it will have some stamped numbers. One of these numbers will be the offset, if you can get all the info you can find and post it there will be more help.As for the CAPA tune that probably is the cause of the idle issue. You should be able to plug it in and return to stock. Has your car got standard injectors? 1 Link to comment Share on other sites More sharing options...
Chemarrie Member 58 Member For: 11y 10m 13d Gender: Female Location: Blacktown Posted 04/01/13 10:06 AM Author Share Posted 04/01/13 10:06 AM Just a note of those Hub spacers how much are they around and does anyone install them?I was worried that if I put the wheels outside on spacers that I would hit the inside kit when I turn the wheels.I am also worried that I will need a pretty big spacer to clear that metal thing maybe at least 5 cm is this possible? Link to comment Share on other sites More sharing options...
Panda Eyes flame magnet Gold Donating Members 5,674 Member For: 16y 5m 28d Gender: Male Location: adelaide hills- 'race air' central Posted 04/01/13 10:06 AM Share Posted 04/01/13 10:06 AM 1 Link to comment Share on other sites More sharing options...
Panda Eyes flame magnet Gold Donating Members 5,674 Member For: 16y 5m 28d Gender: Male Location: adelaide hills- 'race air' central Posted 04/01/13 10:10 AM Share Posted 04/01/13 10:10 AM (edited) yep I started a thread on the wheels section with details of a hub spacer supplier in the us.you wont have much clearance at the best of times with 20's (2-3mm is normal). as I said before, find out the offset of the car they came off and see what the difference is between that and +35 (mm). looks like they may be 0 offset, as (guessing) 35mm would do... Edited 04/01/13 10:10 AM by Panda Eyes 1 Link to comment Share on other sites More sharing options...
Chemarrie Member 58 Member For: 11y 10m 13d Gender: Female Location: Blacktown Posted 04/01/13 10:10 AM Author Share Posted 04/01/13 10:10 AM Somewhere on the inside of the rim it will have some stamped numbers. One of these numbers will be the offset, if you can get all the info you can find and post it there will be more help.As for the CAPA tune that probably is the cause of the idle issue. You should be able to plug it in and return to stock. Has your car got standard injectors?Ok so my offset it ET 45 its stamped inside the rims.Are they really 20's lol wtf I really need to do my research hahahaCapa tuner I dont think was installed yet the guy brought it for the car to get done for idleing issues but never got it done from what I know.I dont know where to install the capa tuner does any one have a grid or pic =) Link to comment Share on other sites More sharing options...
Panda Eyes flame magnet Gold Donating Members 5,674 Member For: 16y 5m 28d Gender: Male Location: adelaide hills- 'race air' central Posted 04/01/13 10:12 AM Share Posted 04/01/13 10:12 AM (edited) what width are the rims? (should say on the inside 20 x ??jj) Edited 04/01/13 10:12 AM by Panda Eyes Link to comment Share on other sites More sharing options...
