  • Member For: 14y 7m 30d
  On 04/01/2013 at 1:04 PM, jimmixr said:
Id say your belt tensioner.. they lose their tension and rattle. With 100k Id look at changing the drive belt at the same time.
Worst case scenario it just my be your timing chain tensioner and/or chain guides...
  • 3 weeks later...
  • Member For: 14y 2m 30d
I had the same noise, it wqs after I pressure washed the engine bay.
Then I was getting a knock sensor fault code. It was the belt tensioner. The plastic parts that are supose to slip as the belt tension changes while belt it running around the pulleys. were dry. and made a knock sound that was enough to set off the knock sensor.
Easy fix, pull off and lubricate with INOX grease.
