  • Member For: 21y 9m 15d
A mate of mine had this done on a BA MkII XR6T manual, they had to change an oil pressure unit or somthing - car went well, with everything else kept stock.
  • 1 month later...
  • Member For: 16y 10m 28d
I have seen an fg g6e turbo been loaded with an f6 tune in it and there is no issues with brakes and no oil lights nothing. I have driven the car myself and for a stocka I was surprised it was quick for what it was. there is away around it but no one whats to speak of it because ford will crucify the person who does it. basically as far as I know you need a ford id and then you can mess with sh...t! so yes its possible and yes there is a way to remove the faults but you need to suck up to ford dealer or something along the lines. as far as I know alot of the pcms are the same (I believe they are the same in all of them besides ba bf fg have a better hardware as they go along.) or able to deal with software changes such as fg xr to fg fpv. im no ford expert but I have heard of ways around it besides using an excal or some other tuning brand. but without the excal or whatever brand you choose you wont be able to custom tunes with out the excal or whatever brand you choose
  • Bronze Donating Members
  • Member For: 13y 9m 2d
I think youve been lied to lol
What is a ford id? Between ba-fg there are over 20 different pcms. For an fg especially the standard f6 tune presents issues due to 1. The smaller turbo and smaller injectors on the g6et 2. The completely different abs module and dsc programming. It simply is not possible using ids software.
  • Like 3
well each to there own. do you really think ford would go out of there way to make a complete new pcm for a f6 then a xr6 turbo. no they wouldnt the funds wouldnt be worth it. ok maybe a na, lpg, v8 and turbo yea I know that's true. trust me its possible. basicallly your saying like people once said once before ford pcm cant be cracked and tuned with the original pcm. well now we have few brands which now make software to tune ba to fg. if your in the know how you can do it put it to you that way.
ford will not let you know that. its just a computer. its like putting vista to windows 7 its just abit of ...cking around. so I apologies to you I beleive you been lied to and miss informed. as I said once before anything is possible but if they are caught ford will crucify the person who updates the software to that or whatever. I have heard of people getting around it
look yes I thought it was strange to but I have faith in it is possible seeing that pcm has been cracked once before, and well what so different between ford to fpv because my cross breed ford seems to work fine with a fpv abs pump and ba pcm and etc
Well its my job to know that its not possible soooo yeah... And I can give you a list of the 20 plus part numbers for pcms if youd like? Using our IDS software it IS NOT POSSIBLE to flash an f6 tune into a g6et and have it run correctly. FACT
mate there is no difference. yes I can agree with possibly injectors and turbo. I was told the same thing with the ford territory brakes wont fit a fg sedan or ute or anything but territory. I have put territory brakes on ba to f6 sedan utes on few occasions. I have installed a head unit from a fpv to ford and just changing the bem. ( basic single zone to single colour)
Edited by P_BA_XR6
Big woop none of that is new... But what you are saying here is that ford ids software flashed an f6 tune into a g6e which has different injectors and turbo therefore different injector scaling/timing/airflow etc which is 110% impossible to do and have it run correctly
Edited by bionicxr6t05
