Steven87 Member 109 Member For: 13y 1m 6d Gender: Male Location: Westside Posted 03/01/13 09:43 AM Author Share Posted 03/01/13 09:43 AM What hose did u use. Did u use the same as factory hose. And how how long was it. Link to comment Share on other sites More sharing options...
Steven87 Member 109 Member For: 13y 1m 6d Gender: Male Location: Westside Posted 03/01/13 09:49 AM Author Share Posted 03/01/13 09:49 AM Was thinking about just to be on the safe side about the hose not to loop ill just take my pump and get these guys on eBay to fit it in the larger fuel cradle pod Link to comment Share on other sites More sharing options...
Steven87 Member 109 Member For: 13y 1m 6d Gender: Male Location: Westside Posted 03/01/13 09:51 AM Author Share Posted 03/01/13 09:51 AM (edited) Just gotta wait and see if it dose it again, waiting game :(Would love to fix this starting problem as I have a feeling it will come back in a bad time. But hasn't done it today Edited 03/01/13 09:52 AM by Steven87 Link to comment Share on other sites More sharing options...
Bonjaz Donating Members 1,841 Member For: 16y 1m 3d Gender: Male Location: CQ Posted 03/01/13 10:41 AM Share Posted 03/01/13 10:41 AM I used submersible fuel line in my old bf when I did it and stainless hoseclamps, the submersible sh*t wasnt cheap, from memory about $30 a foot from repco I think I used 2 80ish mm pieces I think. I think my tuner told me to use 5/16 hose but for the life of my couldnt get it to fit so I think I ended up with 3/8? It was a few years ago so my measurements might be wrong Link to comment Share on other sites More sharing options...
jas98 Member 1,046 Member For: 12y 5m 18d Gender: Male Location: Maryborough Qld Posted 03/01/13 11:33 AM Share Posted 03/01/13 11:33 AM these arfe supposably GOSS brand (just has too many or something) whole module, would be cheaper the buying that submersible hose lol as you take your pump out and reassemblehttp://www.ebay.com.au/itm/FORD-FALCON-BA-BF-SEDAN-XR6-TURBO-BARRA-240T-4-0L-6CYL-XR8-BOSS-FUEL-PUMP-ASSY-/221093434828?pt=AU_Car_Parts_Accessories&hash=item337a3215cc&_uhb=1#ht_2593wt_906 Link to comment Share on other sites More sharing options...
Steven87 Member 109 Member For: 13y 1m 6d Gender: Male Location: Westside Posted 04/01/13 09:57 AM Author Share Posted 04/01/13 09:57 AM Just went outside to start the car up and guess what it turned of and didn't want to start, so I checked for fuel and had no fuel. I couldn't hear the walbro pump so I went the relays and swapped it for the horn one and it started up. Then I turned the car off and put the original reply in and it started up with it. So now in not sure could it be a sticking relay and when I removed it then it decided to work. Might just buy a new relay Is it common for a fuel relay to goJust cause the walbro is like 1600kms old Link to comment Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 13y 5m 14d Gender: Male Posted 04/01/13 10:00 AM Share Posted 04/01/13 10:00 AM If you could hear the fuel pump the relay will be fine.... Maybe the check valve is sticking on the pump causing it to lose pressure when its switched off, you got a fuel pressure gauge on it yet? Link to comment Share on other sites More sharing options...
Steven87 Member 109 Member For: 13y 1m 6d Gender: Male Location: Westside Posted 04/01/13 10:20 AM Author Share Posted 04/01/13 10:20 AM Na when I first hoped into the car to start it I had the radio off to see if I could hear it and nothing but I tried to crank it and it turned off straight away. That's when I checked and had no fuel so I swapped the relays with the horn one and it started but when I put the original fuel pump relay bak it started up so in not sure if it could be a sticky relay and it worked when I played around with it. I never put a fuel pressure gauge on. Might just buy new relay and see how it goes. Link to comment Share on other sites More sharing options...
jas98 Member 1,046 Member For: 12y 5m 18d Gender: Male Location: Maryborough Qld Posted 04/01/13 02:56 PM Share Posted 04/01/13 02:56 PM was it a pump from ebay? some say there walbro but are copys. is yours genuine? Link to comment Share on other sites More sharing options...
Steven87 Member 109 Member For: 13y 1m 6d Gender: Male Location: Westside Posted 04/01/13 06:34 PM Author Share Posted 04/01/13 06:34 PM Well I bought it through autobahn just to make sure it would be 100% genuine Link to comment Share on other sites More sharing options...
