f6mark Member 2,908 Member For: 13y 9m 9d Gender: Male Posted 01/01/13 04:48 AM Share Posted 01/01/13 04:48 AM iv got the walbro intake pump 300+ & PW surge&044 pump 750cc Xspurt injectors only on 98 bp pump for now. 2 Link to comment Share on other sites More sharing options...
R3dmist Member 68 Member For: 12y 2m 11d Gender: Male Location: blue mountains Posted 01/01/13 05:02 AM Share Posted 01/01/13 05:02 AM I to have the intank walbro. PW surge with 044. 1000cc injectors. Had initial issues with the walbro.. But since been on E85, no issues... Fingers crossed 3 Link to comment Share on other sites More sharing options...
CCCC miso xr6 Donating Members 317 Member For: 15y 11m 14d Posted 01/01/13 05:03 AM Author Share Posted 01/01/13 05:03 AM Cccc your ride sounds tough is it a grey car with a sweet sticker on the rear window? How much boost you running?"."Lol yea that's me, running 17psi 410rwkw, 155 thousand kay ba standard block, you may have witnessed when I was running 24psi on normal 98 unleaded pump after I got an intake mod done, now I can tell you lol that's spooling an getting your boost on:) 3 Link to comment Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 2m 19d Gender: Male Location: Townsville Posted 01/01/13 05:09 AM Share Posted 01/01/13 05:09 AM Sounds like Molasses! Link to comment Share on other sites More sharing options...
relentless xr6 Member 363 Member For: 13y 11m 19d Gender: Male Location: Sydney Posted 01/01/13 06:39 AM Share Posted 01/01/13 06:39 AM Glad to hear you got it all sorted mate well done good write up on a problem that alot more people will see in a few years 3 Link to comment Share on other sites More sharing options...
rednose RNS10S Donating Members 2,229 Member For: 18y 3m 7d Gender: Male Posted 01/01/13 10:29 PM Share Posted 01/01/13 10:29 PM I have a similar setup to Miso (CCCC) but 80lb injectors,I have not had an issue with e85 yet but as Miso said the problem would have been due to old gunk in the fuel system which the e85 cleaned out.Good to hear the car is running great again Miso. 2 Link to comment Share on other sites More sharing options...
KPM Motorsport Member 968 Member For: 19y 1m 1d Gender: Male Location: 2 Dunorlan Road Edwardstown S.A. 08 82999998 Posted 02/01/13 10:56 PM Share Posted 02/01/13 10:56 PM As per new vehicle manufacturers and component manufacturers dedicating their systems to run both Petrol and E85, every precaution is taken in the materials used.Fuel lines, fuel pumps , injectors and fuel tanks are all made of anti-corrosive materials.We are currently seeing problems arise from dedicated petrol vehicles that are running E85 without correct retrofitting.Unlike petrol , ethanol is hygroscopic (absorbs moisture ) and has corrosive tendancies.Over a long or short period this causes oxidation and detiriation on reactive materials therefore causing goo and particles ending at your injectors. Correct fuel lines, stainless steel modern injectors, stainless steel fittings, stainless steel fuel rails and tanks will all minimise any currant and future problems running flex fuels. 2 Link to comment Share on other sites More sharing options...
Impellor Member 835 Member For: 14y 4m 3d Gender: Not Telling Posted 02/01/13 11:23 PM Share Posted 02/01/13 11:23 PM KPM, I wonder if you could highlight area's of our Falcon that require attention . For example is the plastic fuel tank suitable. Cheers 2 Link to comment Share on other sites More sharing options...
KPM Motorsport Member 968 Member For: 19y 1m 1d Gender: Male Location: 2 Dunorlan Road Edwardstown S.A. 08 82999998 Posted 03/01/13 04:46 AM Share Posted 03/01/13 04:46 AM (edited) KPM, I wonder if you could highlight area's of our Falcon that require attention . For example is the plastic fuel tank suitable.CheersThe B and F series Falcons have all the correct gear to support E85 if left standard.Plastic tanks in modern cars are fine and etahnol resistant.E85 may cause problems when aftermarket modifications are added that can deteriate when using flex fuels.Some examples can be untreated aluminium components , non modern style rubber fuel lines.mild steel or lead style fuel tanks etc , older style fuel injectors. Edited 03/01/13 09:53 PM by KPM Motorsport 2 Link to comment Share on other sites More sharing options...
Never had any say Panda I <3 Floods Silver Donating Members 11,198 Member For: 13y 3m 22d Gender: Male Location: South West QLD Posted 03/01/13 04:50 AM Share Posted 03/01/13 04:50 AM Is it true that E85 causes mild steel exhausts to deteriorate a lot faster? Link to comment Share on other sites More sharing options...
