Red R6 Donating Members 41 Member For: 12y 6m 26d Posted 29/12/12 10:57 PM Share Posted 29/12/12 10:57 PM (edited) STAINO If you have a more qualified source for your info then Garrett feel free to post it. Edited 29/12/12 10:57 PM by Red R6 Link to comment https://www.fordxr6turbo.com/forum/topic/83368-ceramic-coating-turbo/page/2/#findComment-1342279 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,584 Member For: 17y 2m 23d Gender: Male Location: Melbourne Posted 30/12/12 07:29 AM Share Posted 30/12/12 07:29 AM I think staino is referring to this. Have a quick read. Link to comment https://www.fordxr6turbo.com/forum/topic/83368-ceramic-coating-turbo/page/2/#findComment-1342450 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 10d Gender: Male Location: Perth Posted 30/12/12 07:39 AM Share Posted 30/12/12 07:39 AM Here we go^WHS Link to comment https://www.fordxr6turbo.com/forum/topic/83368-ceramic-coating-turbo/page/2/#findComment-1342458 Share on other sites More sharing options...
Red R6 Donating Members 41 Member For: 12y 6m 26d Posted 30/12/12 09:16 AM Share Posted 30/12/12 09:16 AM (edited) I had a read and Nizpro is welcome to believe what it wants but I will stick with what the engineers at Garrett sayQ. What is compressor surge?A. The surge region, located on the left-hand side of the compressor map (known as the surge line), is an area of flow instability typically caused by compressor inducer stall. The turbo should be sized so that the engine does not operate in the surge range. When turbochargers operate in surge for long periods of time, bearing failures may occur. When referencing a compressor map, the surge line is the line bordering the islands on their far left side. Compressor surge is when the air pressure after the compressor is actually higher than what the compressor itself can physically maintain. This condition causes the airflow in the compressor wheel to back up, build pressure, and sometimes stall. In cases of extreme surge, the thrust bearings of the turbo can be destroyed, and will sometimes even lead to mechanical failure of the compressor wheel itself. Common conditions that result in compressor surge on turbocharger gasoline engines are:-A compressor bypass valve is not integrated into the intake plumbing between the compressor outlet and throttle body-The outlet plumbing for the bypass valve is too small or restrictive-The turbo is too big for the applicationI understand Nizpro are well respected people but I will take a Garrett engineers word over Nizpro's anydayhttp://www.turbobygarrett.com/turbobygarrett/faq Edited 30/12/12 09:16 AM by Red R6 Link to comment https://www.fordxr6turbo.com/forum/topic/83368-ceramic-coating-turbo/page/2/#findComment-1342537 Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 5m 15d Gender: Male Location: Christchurch, New Zealand Posted 30/12/12 09:50 AM Share Posted 30/12/12 09:50 AM On a side note, being that your only planning on ceramic coating the exhaust side of the turbo. Should the ceramic coating have built up enough to damage your turbine its only going down the exhaust not through your engine so you won't really have to worry to much about that. And when reassembling the turbo I would hope you would spin it by hand to check its free and not binding before actually installing it. Link to comment https://www.fordxr6turbo.com/forum/topic/83368-ceramic-coating-turbo/page/2/#findComment-1342546 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 10d Gender: Male Location: Perth Posted 30/12/12 10:23 AM Share Posted 30/12/12 10:23 AM I had a read and Nizpro is welcome to believe what it wants but I will stick with what the engineers at Garrett sayQ. What is compressor surge?A. The surge region, located on the left-hand side of the compressor map (known as the surge line), is an area of flow instability typically caused by compressor inducer stall. The turbo should be sized so that the engine does not operate in the surge range. When turbochargers operate in surge for long periods of time, bearing failures may occur. When referencing a compressor map, the surge line is the line bordering the islands on their far left side. Compressor surge is when the air pressure after the compressor is actually higher than what the compressor itself can physically maintain. This condition causes the airflow in the compressor wheel to back up, build pressure, and sometimes stall. In cases of extreme surge, the thrust bearings of the turbo can be destroyed, and will sometimes even lead to mechanical failure of the compressor wheel itself. Common conditions that result in compressor surge on turbocharger gasoline engines are:-A compressor bypass valve is not integrated into the intake plumbing between the compressor outlet and throttle body-The outlet plumbing for the bypass valve is too small or restrictive-The turbo is too big for the applicationI understand Nizpro are well respected people but I will take a Garrett engineers word over Nizpro's anydayhttp://www.turbobygarrett.com/turbobygarrett/faq Compressor surge and flutter from no bov = not same/same.. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/83368-ceramic-coating-turbo/page/2/#findComment-1342555 Share on other sites More sharing options...
Impellor Member 835 Member For: 14y 11m 13d Gender: Not Telling Posted 30/12/12 10:35 AM Share Posted 30/12/12 10:35 AM Red R6, welcome aboard mate. But I already have an awareness, that you have little understanding. I suggest you don't believe everything you read. Maybe talk about how ceramic coating improves thermal velocity. Cheers 1 Link to comment https://www.fordxr6turbo.com/forum/topic/83368-ceramic-coating-turbo/page/2/#findComment-1342560 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 10d Gender: Male Location: Perth Posted 30/12/12 10:39 AM Share Posted 30/12/12 10:39 AM ^^^^This guy^^^ 1 Link to comment https://www.fordxr6turbo.com/forum/topic/83368-ceramic-coating-turbo/page/2/#findComment-1342562 Share on other sites More sharing options...
STAINLESS again plz You've changed man.... Donating Members 8,142 Member For: 14y 6m 6d Gender: Male Location: 2 Fuchsia Court, Narre Warren. 3805 Posted 30/12/12 10:39 AM Share Posted 30/12/12 10:39 AM ... Link to comment https://www.fordxr6turbo.com/forum/topic/83368-ceramic-coating-turbo/page/2/#findComment-1342563 Share on other sites More sharing options...
Red R6 Donating Members 41 Member For: 12y 6m 26d Posted 30/12/12 10:57 AM Share Posted 30/12/12 10:57 AM Compressor surge is when the air pressure after the compressor is actually higher than what the compressor itself can physically maintain Link to comment https://www.fordxr6turbo.com/forum/topic/83368-ceramic-coating-turbo/page/2/#findComment-1342566 Share on other sites More sharing options...
