Adam Here since the start... Lifetime Members 10,282 Member For: 22y 16d Gender: Male Location: Victoria Posted 29/12/12 09:24 PM Share Posted 29/12/12 09:24 PM Don't regap the plugs. What Jet's talking about can happen under load with cars running a higher boost level. Your issue is at idle so the gap won't be a problem. 2 Link to comment https://www.fordxr6turbo.com/forum/topic/83367-rough-idle-have-tried-just-about-everything-stumped/page/4/#findComment-1342257 Share on other sites More sharing options...
MX Dave Donating Members 545 Member For: 14y 1m 7d Gender: Male Posted 30/12/12 02:28 AM Share Posted 30/12/12 02:28 AM Dumb question, how did you torque your spark plugs?No offence intended but seen many people crack them before from over tightening. Then refuse to replace them because they are 'new'Food for thought. Link to comment https://www.fordxr6turbo.com/forum/topic/83367-rough-idle-have-tried-just-about-everything-stumped/page/4/#findComment-1342339 Share on other sites More sharing options...
jas98 Member 1,046 Member For: 12y 9m 19d Gender: Male Location: Maryborough Qld Posted 30/12/12 03:26 AM Share Posted 30/12/12 03:26 AM (edited) On 29/12/2012 at 9:01 AM, J@SNOT said: hold your foot flat to the floor and click the key to start for 2 seconds approx ( it wont start but will crank ) then switch key back to off then foot off then start it as per normalwhat does this do? ive been told it does nothing at allalso another thing I did on mine yesterday was check all boost lines and I found the boost pipe under turbo that leads to turbo from intercooler I could do the clamp up about 6-8 turns. im pretty sure it helped allot with mine also found loose spark plugs on mine aswell... Edited 30/12/12 03:28 AM by jas98 Link to comment https://www.fordxr6turbo.com/forum/topic/83367-rough-idle-have-tried-just-about-everything-stumped/page/4/#findComment-1342355 Share on other sites More sharing options...
NickBA-XR6T Bronze Donating Members 386 Member For: 13y 2m 1d Posted 30/12/12 06:05 AM Author Share Posted 30/12/12 06:05 AM Will check that under car boost hose never thought of that. Plugs I do firm but not too tight. The bad idle was there on the last set of plugs too so doubt it is that. Link to comment https://www.fordxr6turbo.com/forum/topic/83367-rough-idle-have-tried-just-about-everything-stumped/page/4/#findComment-1342399 Share on other sites More sharing options...
MX Dave Donating Members 545 Member For: 14y 1m 7d Gender: Male Posted 30/12/12 06:48 AM Share Posted 30/12/12 06:48 AM I doubt that would make any difference to idle as its under vacuum so anything leaking before the map sensor shouldn't affect idle.When you checked for vacuum leaks did you check the brake booster. That often gets overlooked for slight air leaks.I've had a car before we're the brakes still felt okay but the booster had an air leak causing sh*t idle. Link to comment https://www.fordxr6turbo.com/forum/topic/83367-rough-idle-have-tried-just-about-everything-stumped/page/4/#findComment-1342434 Share on other sites More sharing options...
NickBA-XR6T Bronze Donating Members 386 Member For: 13y 2m 1d Posted 31/12/12 04:48 AM Author Share Posted 31/12/12 04:48 AM OK so today I ripped the whole thing apart. Tightened everything. Found a dodgy rubber joiner on the turbo inlet and replaced that with a blue silicone joiner. Tightened the upper inlet manifold bolts I could get to. Exhaust manifold bolts are OK. Tightened the turbo nuts. Tightened the spark plus 2 were on the soft side. Checked all hoses. Idles quite a bit better now. Not perfect but better. Link to comment https://www.fordxr6turbo.com/forum/topic/83367-rough-idle-have-tried-just-about-everything-stumped/page/4/#findComment-1342739 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 11d Gender: Male Location: Adelaide Posted 31/12/12 05:09 AM Share Posted 31/12/12 05:09 AM Semi win then lol Link to comment https://www.fordxr6turbo.com/forum/topic/83367-rough-idle-have-tried-just-about-everything-stumped/page/4/#findComment-1342743 Share on other sites More sharing options...
NickBA-XR6T Bronze Donating Members 386 Member For: 13y 2m 1d Posted 31/12/12 08:20 AM Author Share Posted 31/12/12 08:20 AM Lol indeed. I think I will send it to Autotech for further diagnosis. Just to be sure. Link to comment https://www.fordxr6turbo.com/forum/topic/83367-rough-idle-have-tried-just-about-everything-stumped/page/4/#findComment-1342820 Share on other sites More sharing options...
gsd112 Donating Members 604 Member For: 14y 8m 7d Gender: Male Location: Penrith Posted 31/12/12 09:07 AM Share Posted 31/12/12 09:07 AM On 31/12/2012 at 8:20 AM, NickBA-XR6T said: Lol indeed. I think I will send it to Autotech for further diagnosis. Just to be sure.Good idea, he is a whizz with these cars Link to comment https://www.fordxr6turbo.com/forum/topic/83367-rough-idle-have-tried-just-about-everything-stumped/page/4/#findComment-1342828 Share on other sites More sharing options...
jas98 Member 1,046 Member For: 12y 9m 19d Gender: Male Location: Maryborough Qld Posted 01/01/13 02:37 AM Share Posted 01/01/13 02:37 AM On 30/12/2012 at 6:48 AM, MX Dave said: I doubt that would make any difference to idle as its under vacuum so anything leaking before the map sensor shouldn't affect idle.When you checked for vacuum leaks did you check the brake booster. That often gets overlooked for slight air leaks.I've had a car before we're the brakes still felt okay but the booster had an air leak causing sh*t idle.hmm been thinking this with mine as not a miss just bad vibration cause of a bad idle. it idles round 700rpm even lower sometimes. but when take foot off brake and go (from lights ) if fine. or when reved slightly it finewhat the best way to check booster?? foot off brake in drive? hand break on? Link to comment https://www.fordxr6turbo.com/forum/topic/83367-rough-idle-have-tried-just-about-everything-stumped/page/4/#findComment-1342962 Share on other sites More sharing options...
