  • Bronze Donating Members
  • Member For: 13y 1m 4d
OK so I have done:
Spark plugs
Coils
Fuel filter
Fuel regulator
Throttle body
Checked for vac leaks
Reset ECU
O2 sensor with genuine NTK
I cannot find a reason for my bad idle which consists of a constant miss. Can anybody suggest anything else I am all out of money and patience.
Regards
Nick
And the throttle body was a complete replacement with TPS.
  • Member For: 13y 8m 19d
Could be injector, carbon buildup on valves, bent rod, jumped timing
Ford can do a cylinder balance to identify which cylinder it is or you can unplug coils one at a time
A damaged piston/headgasket/valveseat can also cause this
  • Special needs member.
  • Member For: 14y 7m 9d
  • Member For: 13y 4m 2d
Nothing cheap to check anymore. I assume you have checked all clamps etc? You can start the T with the air intake off it (remove the cross-over and just have the throttle body exposed) That eliminates the turbo, and associated pipes - cooler - and air system. Start it but Don't rev it up. If it still misses, we get down to an injector or a head gasket as a next step. A compression test is where I would go first. That is not money badly spent because you will then know what the engine is like. After that, (if no good)- to the dealer and they should be able to advise which cylinder is "lost."
Good luck - {my idle issue was a plug and a coil....... naturally they were not on/in the same cylinder so it was plugs/coils/........... clean throttle body is regular servicing.}
The codes were lean bank 1 which a genuine o2 sensor fixed and idle air control under speed so I replaced the throttle body. Having the codes reset today. Still didn't fix my idle though. I'm thinking it may be a bad injector.
The engine has only done 125,000 and under load it seems to go well. The fuel consumption is up around 16.8l/100 which is high considering I don't thrash it everywhere. I doubt its a head gasket as no oil in the water or water in the oil etc. My gut tells me its a manifold leak should I have someone do a smoke test on it?
