Cylinder Heads Na / Turbo
LOFTY1
  • Bronze Donating Members
  • Member For: 13y 2m 12d
I've Looking To Build Up an Engine For My Ba XR6t Ute ( Stuck In The Low 300 Club ) I've Have Heard Of People Using N/a Ba Bottom Ends For Internal Transplants ( Spool Imports ) With No Problems, My Question Is About The Cyl Heads, Is The Ba N/A Cyl Head Cast The Same As The Turbo Version? Valves? Cams? If Not Is The BF2 Head The One You Want ? Or Is The Turbo Head Out On It's Own ? Any Info Would Be Nice Cheers. So Want 400+
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 7m 7d
Na is phisically same (b series ) but the valves and camms are different,I believe this is as far as the differances go
  • Moar Powar Babeh
  • Member For: 19y 3m 15d
Turbo head is different. Different Valves and Seats
Re cam for each series cams are the same between NA and Turbo. (ie ba same/same bf different to ba but same/same across bf model range)
Only difference im aware of is FGF6 cams being differnet to FG NA and XR6t
Cheers for Quick Reply , So Cyl Head Castings Same Valve & Valve Seats Different, Cams Different , Basically If I Was To Rebuild BA Na Mtr Could Only Use Bottom End & Should Then Chase Up Turbo Head Of BF ? Cheers.
  • 3 weeks later...
