  • Member For: 13y 9m 29d
anyone done or seen SSSL fronts? whats that like? might be a bitch to drive I think so I may just go SSL fronts and reset the rear leafs to hang low like sugar dunkington low!
  • Member For: 14y 10m 5d
Yep.. had them in for awhile. Ride wasnt too bad at the start.. but they headed south, sagged a bit too much for my liking. Threw the SSLs' back in. Hope they settle abit .
  • FREAKY
  • Member For: 15y 5m 30d
  On 02/01/2013 at 11:59 PM, BOSSGTE said:
Where do people recommend to get their FG lowered in Melbourne? A mate just had his G6E Turbo done at Suspension City(? - never heard of them before) with SSL/SSSL - it looks great. Im wondeirng if having the extra weight of an 8 means I should just go SL in the front. Thoughts? Suggestions?
they will look after you. they do shyte loads of cars.
yes they did mine
go ssl/sssl combo
go ssl fronts
reset rear to match
  • Member For: 12y 6m 30d
hey people,
ssl/sssl combo (or even sl/ssl)
how bad does the camber go? I know comodores eat tires when dropped, id assume the fords do the same?
also, how many of you replace the shocks at the same time, and or trim the bump stops.
cheers.
  On 08/01/2013 at 11:38 AM, Ford Freak said:
go ssl fronts
reset rear to match
Looks like I'll be going SSL fronts with blistens then. thanks for the word of warning amigos!
  On 08/01/2013 at 9:28 PM, Ford Freak said:
Sl is basically stock xr height
Don't bother.
so SSL isnt that much lower :(
FYI running a 8.5 20" up front with +25
tyre is a 225.........thinking about buying a 25mm spacer for a bit more poke...should be fine hey on ssl?
cause my 10.5 on the rear is running a 275 and I wanted the stretch to look the same as the back. we have a 245 but 225 mimics rears nicely
  • FREAKY
trust me if you want your car to look lowered you need ssl up front.
id also suggest putting shims in the front to eliminate some camber problem. its cheap or get a kit.
not too sure about the rears for sedans with camber.
ute ftw!
  • Like 3
