trentd Member 5 Member For: 14y 2m 26d Posted 27/02/13 03:37 AM Share Posted 27/02/13 03:37 AM On 27/02/2013 at 3:23 AM, willo88 said: ^^^your car is to high and probably rolls around like a boat if you haven't changed/cut your bump stopsdoesn't handle like a boat, just bouncy.Taking into consideration, the xyz coilovers are a lot shorter then the standard ones, so even when the spring is adjusted high they seem to be touching, I can increase the length of the shock (rebound - correct if wrong), hopefully this might help.Just for info, as it sits now it is still a fair gap above the wheel, I don't want it dragging on the ground I just like a bit of tire tuck. Link to comment https://www.fordxr6turbo.com/forum/topic/83348-show-us-your-lowered-fg-sedan-utes/page/21/#findComment-1366999 Share on other sites More sharing options...
Seaton Donating Members 537 Member For: 12y 8m 1d Gender: Male Location: Sydney Posted 27/02/13 11:00 AM Share Posted 27/02/13 11:00 AM Yep, my SSSL rear needed cut bumps. They are actually close to them on stock springs. Link to comment https://www.fordxr6turbo.com/forum/topic/83348-show-us-your-lowered-fg-sedan-utes/page/21/#findComment-1367192 Share on other sites More sharing options...
XtRmn8 570Nm @1800rpm Donating Members 2,441 Member For: 21y 7m 6d Gender: Male Location: Perth, WA Posted 28/02/13 03:20 AM Share Posted 28/02/13 03:20 AM Pics below of SSL rear with trimmed bump stops. If they were not trimmed there would be less then 5mm clearance between the bump stop and arm. Link to comment https://www.fordxr6turbo.com/forum/topic/83348-show-us-your-lowered-fg-sedan-utes/page/21/#findComment-1367393 Share on other sites More sharing options...
jimmixr Donating Members 686 Member For: 14y 8m 9d Posted 28/02/13 04:07 AM Share Posted 28/02/13 04:07 AM On 27/02/2013 at 3:08 AM, trentd said: what wheels are they!!TSW Nurberings 20x10 & 20x8.5 Link to comment https://www.fordxr6turbo.com/forum/topic/83348-show-us-your-lowered-fg-sedan-utes/page/21/#findComment-1367406 Share on other sites More sharing options...
CDR_078 Member 87 Member For: 13y 4m 12d Posted 01/03/13 08:51 AM Share Posted 01/03/13 08:51 AM On 28/02/2013 at 3:20 AM, XtRmn8 said: Pics below of SSL rear with trimmed bump stops. If they were not trimmed there would be less then 5mm clearance between the bump stop and arm.Did you do this yourself mate? How much of a mission is it? Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/83348-show-us-your-lowered-fg-sedan-utes/page/21/#findComment-1367844 Share on other sites More sharing options...
Bellato Donating Members 2,713 Member For: 14y 6m 9d Posted 01/03/13 09:04 AM Share Posted 01/03/13 09:04 AM ^^ trimming bump stops or doing the springs?Both easy for the matter lol Link to comment https://www.fordxr6turbo.com/forum/topic/83348-show-us-your-lowered-fg-sedan-utes/page/21/#findComment-1367853 Share on other sites More sharing options...
XtRmn8 570Nm @1800rpm Donating Members 2,441 Member For: 21y 7m 6d Gender: Male Location: Perth, WA Posted 01/03/13 10:02 AM Share Posted 01/03/13 10:02 AM I cut the bump stops when I was fitting the springs. They pull out easy and you can cut them with a hacksaw or sharp knife.They are easy to get to so you should have no dramas trimming them without having to pull then out. Link to comment https://www.fordxr6turbo.com/forum/topic/83348-show-us-your-lowered-fg-sedan-utes/page/21/#findComment-1367870 Share on other sites More sharing options...
CDR_078 Member 87 Member For: 13y 4m 12d Posted 01/03/13 12:26 PM Share Posted 01/03/13 12:26 PM Thanks mate, I'm keen to chuck a set of SSSLs in the rear just to see how different it looks / rides. If its none to complex I might have a crack myself. Link to comment https://www.fordxr6turbo.com/forum/topic/83348-show-us-your-lowered-fg-sedan-utes/page/21/#findComment-1367906 Share on other sites More sharing options...
EFSIX I Lead Not Follow... Member 1,026 Member For: 13y 8d Gender: Male Location: Westside,Melbourne Posted 01/03/13 12:33 PM Share Posted 01/03/13 12:33 PM so from all that confusion,you have to cut your bump stops to get more low ?? correction..? Link to comment https://www.fordxr6turbo.com/forum/topic/83348-show-us-your-lowered-fg-sedan-utes/page/21/#findComment-1367907 Share on other sites More sharing options...
andreew Member 101 Member For: 13y 22d Gender: Male Location: Melbourne S.E. Posted 01/03/13 11:49 PM Share Posted 01/03/13 11:49 PM I have the Torana King Springs in the rear. Love the height, never had any dramas from police or anything.Haven't lowered the front yet because lazy.. And I don't know what springs to use. Link to comment https://www.fordxr6turbo.com/forum/topic/83348-show-us-your-lowered-fg-sedan-utes/page/21/#findComment-1367978 Share on other sites More sharing options...
