relentless xr6 Member 363 Member For: 13y 11m 22d Gender: Male Location: Sydney Posted 20/12/12 12:24 AM Author Share Posted 20/12/12 12:24 AM are you running foam allmtr and f*ck me your car is getting lighter everyday man ive just started taking weight out but I try and keep safety in mind aswell do you run a reducer on the a1000 fuel pump because they come out -10 or am I missinformed on that? 1 Link to comment Share on other sites More sharing options...
xr6t_ute Donating Members 2,281 Member For: 17y 5m 1d Gender: Male Location: south east suburbs Posted 20/12/12 01:41 AM Share Posted 20/12/12 01:41 AM You might as well put a cage in it, e85 loves alot more advance so you'll be in the 10's using this fuel. Link to comment Share on other sites More sharing options...
stee3 Member 194 Member For: 13y 5m 1d Posted 20/12/12 01:43 AM Share Posted 20/12/12 01:43 AM I'm still waiting on proof that the standard fuel tank, swirl pot, float etc are compatable with E85Dont know of any that have failed yet only time will tell.are you running foam allmtr and f*ck me your car is getting lighter everyday man ive just started taking weight out but I try and keep safety in mind aswell do you run a reducer on the a1000 fuel pump because they come out -10 or am I missinformed on that?If your rail is dual feed you will need to do like what I have done and use a y fitting to split into 2 lines and have each side going into the fuel rail. Link to comment Share on other sites More sharing options...
relentless xr6 Member 363 Member For: 13y 11m 22d Gender: Male Location: Sydney Posted 20/12/12 09:00 AM Author Share Posted 20/12/12 09:00 AM Single feed and return I'm going to start over the Christmas holidays I hope the a 1000 doesn't run out of puff on me Link to comment Share on other sites More sharing options...
Mr_4.0 Member 1,096 Member For: 13y 10m 7d Posted 20/12/12 09:31 AM Share Posted 20/12/12 09:31 AM Ratter, doesn't pump e85 have anti corrosives in it? I'm pretty sure it does. Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 5m 30d Gender: Male Location: @ my laptop Posted 20/12/12 11:54 AM Share Posted 20/12/12 11:54 AM none of the tech articles I have read have mentioned it being 100% corrosive resistance at all, all mention possible damage to system if not 100% ethanol compatible 1 Link to comment Share on other sites More sharing options...
xr6t_ute Donating Members 2,281 Member For: 17y 5m 1d Gender: Male Location: south east suburbs Posted 20/12/12 11:56 AM Share Posted 20/12/12 11:56 AM (edited) Ratter, doesn't pump e85 have anti corrosives in it? I'm pretty sure it does.They do add these additives to E85..Oh and Ratter, I did have a problem with the surgetank hoses, they were cracked to a inch of its life, process west have given me new ones but he couldnt work out why they were like that as they were meant to be E85 compatible. Edited 20/12/12 11:58 AM by xr6t_ute Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 5m 30d Gender: Male Location: @ my laptop Posted 20/12/12 12:01 PM Share Posted 20/12/12 12:01 PM I had an issue with some Gates E85 hose that failed, had a rep from Gates come to the shop, reimbursed me for the time, went away and organised the hose compound to be changed so as not to happen again, you may have had some of this early hose Link to comment Share on other sites More sharing options...
xr6t_ute Donating Members 2,281 Member For: 17y 5m 1d Gender: Male Location: south east suburbs Posted 20/12/12 12:03 PM Share Posted 20/12/12 12:03 PM Yeh possibly Link to comment Share on other sites More sharing options...
relentless xr6 Member 363 Member For: 13y 11m 22d Gender: Male Location: Sydney Posted 20/12/12 12:57 PM Author Share Posted 20/12/12 12:57 PM Is a plastic cell going to out live a aluminum cell? Link to comment Share on other sites More sharing options...
