Louder Spool
Rydeit
  • Member For: 17y 17d
  On 18/12/2012 at 5:53 AM, HYPEDF6 said:
Sorry to hijack thread.
On the fg's are the intake cone muffler delete pipes worth the money ? is there any noise gain at all ? performance gains ? anything ?
Cheers
Trainer had this with the bov blocked, and it's loud as. And only $180 odd so half that of the growler.
But I imagine based on that, spending $450 on cooler pipes would be best.
  • Member For: 13y 2m 13d
  On 24/12/2012 at 10:38 AM, LAZY6 said:
Why?
The dozing sound is air flowing the wrong way through your turbo.. There is a reason a bov is on the car..
Would blocking another integral part of the car sound logical? Stuff a rag in your exhaust and see how that works. Lmao.
Air surging the wrong way through the compressor leads to shaft play in the turbo.
If your planning on replacing the stocker keep it up, will give you a good excuse for the missus.. But a loose shaft can lead to fouling which leads to metal particles through your motor..
Anyway if you are after the intake noise you want aluminium intake hoses not plastic, they resonate the sound. A bov will only give you the venting noise, as that is what it does.. which varies from make and model ie. Forge sounds like a cash register, the gfb give the pshhht noise and if you add the whistling trumpet it gives you the peeewww noise.
Sent from my GT-I9100 using Tapatalk 2
Edited by jmac86
  • Member For: 12y 6m 17d
As some of the guys said previously, the 4" intake directly from the turbo has a nice induction noise.
Edited by DevilF6
  • Member For: 12y 3m 28d
  On 24/12/2012 at 8:56 AM, jmac86 said:
Dose all day long, until you have to replace a turbo. Lol.
Tell that to the 1000's of VL's + other models with 200k + of doseing.
+1 on the alum 4" intake and pod, it helps amplify the spool sound. No plastic to soak up noise.
