The Converted Donating Members 344 Member For: 13y 8m 14d Gender: Male Location: Melbourne Posted 17/12/12 08:13 AM Share Posted 17/12/12 08:13 AM For those of you who know about true tracs or have one installed in your car and have had the rear end in the air for inspection;Should there be a bit of give between left and right (when rotating one wheel by hand) before it grabs and spins the opposite wheel?Should it spin as an open centre would; when I am spinning one wheel by hand? (I.e. spin one wheel forwards, opposite will spin backwards)Should I be able to stop one wheel by hand when rotating the tail shaft?RegardsMichael Link to comment https://www.fordxr6turbo.com/forum/topic/83253-truetrac-questions/ Share on other sites More sharing options...
Mr_4.0 Member 1,096 Member For: 14y 4m 2d Posted 17/12/12 10:35 AM Share Posted 17/12/12 10:35 AM Do some reading on truetracs. They don't "lock" as such. They actually transfer drive. Link to comment https://www.fordxr6turbo.com/forum/topic/83253-truetrac-questions/#findComment-1337984 Share on other sites More sharing options...
P_BA_XR6 Member 271 Member For: 16y 11m 20d Gender: Male Location: Castle Hill Posted 17/12/12 01:24 PM Share Posted 17/12/12 01:24 PM (edited) Spin tail shaft both wheels will spin at same time and same direction. As said above works by load on each wheel. If you lift a wheel off the ground work the same as single spinner I believe. Edited 17/12/12 01:26 PM by P_BA_XR6 Link to comment https://www.fordxr6turbo.com/forum/topic/83253-truetrac-questions/#findComment-1338036 Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 14y 1m Gender: Male Location: Sydney Posted 17/12/12 03:10 PM Share Posted 17/12/12 03:10 PM (edited) On 17/12/2012 at 8:13 AM, The Converted said: For those of you who know about true tracs or have one installed in your car and have had the rear end in the air for inspection;Should there be a bit of give between left and right (when rotating one wheel by hand) before it grabs and spins the opposite wheel?Should it spin as an open centre would; when I am spinning one wheel by hand? (I.e. spin one wheel forwards, opposite will spin backwards)Should I be able to stop one wheel by hand when rotating the tail shaft?RegardsMichaelyes, yes, haven't tried the 3rd one but I would think so Edited 17/12/12 03:10 PM by Kroozin Link to comment https://www.fordxr6turbo.com/forum/topic/83253-truetrac-questions/#findComment-1338059 Share on other sites More sharing options...
P_BA_XR6 Member 271 Member For: 16y 11m 20d Gender: Male Location: Castle Hill Posted 18/12/12 11:08 PM Share Posted 18/12/12 11:08 PM http://youtu.be/LTXvH3T8BsgDetroit TrueTrac lockers are Torsen style limited slip differentials that use helical gears instead of clutch packs to offer automatic torque biased traction to both drive wheels at all times. The ingenious design limits the speed of each wheel to 1.5 times faster or slower than the opposite wheel to provide full-time traction while still allowing for wheel speed differentiation in turns. The heavy duty all-gear design not only makes for quite and smooth operation, it requires no maintenance and will never weaken or wear out like a typical limited slip differential. These unique features make the Detroit TrueTrac ideal for race cars, rally cars, trail rigs, full size trucks, and daily drivers. The Detroit Truetrac is a Torsen style differential that provides constant power to both drive wheels at all times while still allowing for wheel speed differentiation. The design works so well that the US military chose the Torsen differential as standard equipment on the Hummer H1. Eaton specifically designed and built the Detroit TrueTrac locker for use in 4x4 vehicles and to withstand the abuses of off-roading. Precision forged gears, high strength materials, and high-tech manufacturing procedures make the TrueTrac one of the most durable and reliable limited slip lockers on the market today. They are easy to install and maintenance free. Link to comment https://www.fordxr6turbo.com/forum/topic/83253-truetrac-questions/#findComment-1338614 Share on other sites More sharing options...
P_BA_XR6 Member 271 Member For: 16y 11m 20d Gender: Male Location: Castle Hill Posted 18/12/12 11:13 PM Share Posted 18/12/12 11:13 PM http://www.differentials.com/new-products/detroit-truetrac-limited-slip-differentialshttp://www.drivetrainshop.com/Detroit_TrueTrac_p/eat-913a589.htm Link to comment https://www.fordxr6turbo.com/forum/topic/83253-truetrac-questions/#findComment-1338617 Share on other sites More sharing options...
The Converted Donating Members 344 Member For: 13y 8m 14d Gender: Male Location: Melbourne Posted 19/12/12 02:14 AM Author Share Posted 19/12/12 02:14 AM Thanks for all the help fellas. Link to comment https://www.fordxr6turbo.com/forum/topic/83253-truetrac-questions/#findComment-1338682 Share on other sites More sharing options...
