  • RNS10S
  • Member For: 18y 10m 16d
<blockquote class='ipsBlockquote'data-author="--Jase--" data-cid="1342426" data-time="1356849190"><p>
My local guys are East Coast Customs..<br />
Their argument was that the 1000's are easier to tune, so save you cash on tuning time. And they are more stable/accurate at very low pusle widths saving you cash on fuel.. Use less fuel while at low load.. Which is a good deal of the time while cruising around.<br />
So spending a few bucks extra on the better injector pays for itself very quickly.</p></blockquote>
If you need that much fuel supply then get the 1000's, If not the 60lb/80lb Dekkas will do the job fine.
With regards to fuel usage, on 98 with 50/50 mix freeway/stop start traffic I can get up to 550 klms a tank, on e85 I normally see 380-400klms a tank.
Edited by rednose
  • Member For: 13y 2m 27d
I would think the bosch F6 spec 440cc injectors would handle E85 in a N/A FG. You'd get a good s/c hand set for around $200. Fit straight in - no adaptors or anything else required.
So the stock f6 injectors would be enough to put up with the increased flow rate of e85?
  • Carnage on the Garage Floor
  • Member For: 15y 1m 22d
^^^ I'm at 310rwkw with the F6 injectors running at 85% on 98. I would think a N/A I6 on E85 would not require more fuel than that given I'd doubt you'll sqeeze anymore than 220rwkw out of it.
Edited by Bomber
I would be over the moon with 220rwkw!
Now to be on the hunt for injectors.
Are you running the stock fuel pump for e85?
